Old 07-25-2021, 08:06 PM   #1
Cleveland , Tennessee
Where do you carry your genny fuel?
Just wondering if there is a recommended place on a FC 23FB to put a filled gas can for the generator? I'd rather not carry it in the bed of the pickup with the topper on and my dog riding back there. Best if it were in the open air somewhere. Not a big container, probably 2.5 gallon.
koberudy is offline   Reply With Quote
Old 07-25-2021, 08:22 PM   #2
2007 16' International CCD
Somewhere , Colorado
The interior of the trailer is not good for many reasons. If the truck bed doesn’t work for you, then convert the generator to run on propane.
field & stream is offline   Reply With Quote
Old 07-25-2021, 08:27 PM   #3
Journeyman
2016 25' International
Deerfield , Massachusetts
This question is exactly the reason I converted my generator to propane. It's pretty easy to do, and you're already carrying propane on your rig:
https://www.journeymanblog.net/blog/...run-on-propane
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 07-25-2021, 08:38 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
X2….. propane is the way to go. Lots of onboard fuel on the tongue of the airstream.
wulfraat is offline   Reply With Quote
Old 07-25-2021, 08:55 PM   #5
2007 22' International CCD
X3 gasoline stinks, spills, gums up small engines, and goes stale way too fast. I run a Champion 3400 dual fuel inverter generator only on propane.
Old 07-25-2021, 09:15 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, when my Lincoln Navigator was my tow vehicle, I mounted a Gerry Can mount on top of my battery box. Now with my F-150, my generator and gas can is mounted in the bed of my truck. I started with a 5 gallon Gerry can and changed to a 2 1/2 gallon gas can for ease of use.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 07-25-2021, 09:55 PM   #7
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I prefer gasoline to propane for multiple reasons that I won’t get into here. I agree with the comments above that propane might be a good option for your situation. That said, you might consider something from RotoPax. They make great products for transporting gasoline. I use their fuel packs mounted on a Molle rack in my truck bed, but I think you could find a reasonable way to mount one in the a-frame area on your Airstream.
Have a look at www.rotopax.com. I use the 2-gallon gasoline pack.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 07-25-2021, 10:49 PM   #8
2019 30' Classic
Belen , New Mexico
We use the Wavian NATO fuel cans. they seal tight so there is no leakage or ventage in the back of the truck with the topper on. I'm sure that makes them illegal in California but so are my Honda generators. Wavians are pricey but sturdy.
The default spout is terrible though. They are not long enough so you end up spilling fuel when pouring and I've had two of them break on me which dumped full everywhere. I recommend getting a long-neck flexible fuel spout for it. I've been running with that configuration since 2015 and am very happy with it. I only have two flexible spouts as they fit all the cans. You can also get half size cans for smaller amounts of fuel.
Level 3 Container has a lid adapter which will make it easy to use the BERGS system to feed your generator(s) directly from the NATO can.
If necessary, your generator(s) can run all day/night powering your A/C with little oversight/maintenance.
Since we have no idea how long the gas will sit in the can before use, I also add Amsoil's fuel stabilizer to every can and only use ethanol-free gas.
I've successfully used fuel stored this way as old as 3 years. The fact that the cans don't vent the volatiles off from the fuel and the addition of the stabilizer gives it very long life.
Ephraim is offline   Reply With Quote
Old 07-26-2021, 08:16 AM   #9
Dennis C's Avatar
Another option might be a custom mount on the truck bed topper. Here's an example of a custom RotoPax mount put on the outside of a truck bed topper. This image shows two 2-gallon gasoline cans mounted side-by-side.
Name:	RotoPax custom mount.jpg
Dennis
Old 07-26-2021, 08:25 AM   #10
All good ideas. Thanks
Old 07-26-2021, 09:02 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Gasoline fired gear and fuel really is not a good idea in a living space. Indeed, bulk propane is best left outdoors as well. Stores don't let you bring your propane tank in to swap it out for this very reason.
Storing either fuel and / or the generator in the trailer is unsafe. Even the best of the best containers can leak. Fumes are a big deal sort of hazard in an enclosed area. Explosion or fire are a much bigger issue than the stink.
We all do a lot of unsafe things so it's very much up to you how to proceed.
Old 07-26-2021, 09:13 AM   #12
Mollysdad's Avatar
After a lot of hand wringing I switched to the 'Just Rite' metal gas can.
I use the 2.5 gal because it's easier to lift than the 5 gal. Either one fits into your standard milk crate, so it never tips over and it's easy to tether to the truck bed and the bottom of the can doesn't get dings..
I never smell gas when opening the tonneau. The mechanism is very sturdy for capping the filler and pour spout (different places).
I gave up on leaky plastic cans.
Old 07-26-2021, 09:31 AM   #13
2016 28' International
Perry , Georgia
Totally agree with Mollysdad.
I have the 5 and the 2.5 gal justrite safety can. Cant beat them. No leak no fumes even in the summer.
J-K Georgia is offline   Reply With Quote
Old 07-26-2021, 09:37 AM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I carry the generator full of fuel in the truck bed. I carry an empty gas can. I only fill it if I am going to be in one place on the generator a couple of weeks.
Old 07-26-2021, 09:38 AM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Honda dual fuel...👍 Got both, use both.
ID:	400379   Click image for larger version
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 07-26-2021, 09:42 AM   #16
2021 25' Flying Cloud
Woodbury , CT
Syphon
I was wondering the same thing. But what about a syphon? Just like our Airstreams carry propane, our cars carry Gasoline.
https://www.gastapper.com/store/p1/Standard.html
stevegilmore is offline   Reply With Quote
Old 07-26-2021, 10:02 AM   #17
1964 30' Sovereign
Ione , CA
Propane is a great alternative and offer many practical safety and use benefits.
But for some of us, gasoline is used for the occasional boondocking generator needs.
Typical fuel canisters are terrible (read "whack" where we live in California). Those of us in the ATV and dirt bike world have an excellent option. We typically buy a thick walled plastic tank with molded handles and a wide-mouth large thread screw-on lid with a flexible reinforced fuel tube coming out the top ending in a 1" thread, which allows a 1" secure leak-proof pvc cap to be screwed on. The tank also has a pop off vent plug which eliminates suctioning when pouring. Cleverly, you can buy them at just about any offroad motorcycle dealership (KTM, Honda, Yamaha, etc.). Here in California, they are clearly labeled as not being for fuel but only for water and drinking liquids :-).
Don't store gas in any vehicle in an enclosed space (truck bed with cab). And comments about placing a gasoline canister on top of a battery box give me shivers. It isn't just how it will ride during towing, but always use your 'worst case' imagination to envision what would happen in an accident (trailer jack knifing, trailer disconnecting and dragging on chains, being t-boned from side by another vehicle, tow vehicle rolling, etc.). "An optimist is always unpleasantly surprise while a pessimist is always unpleasantly surprised."
Consider keeping any gasoline canister empty during towing until relatively close to your camping destination. You can't be too careful.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 07-26-2021, 10:26 AM   #18
Half a Rivet Short
Hi
Some of this depends on what you are trying to do. There's lots of reasons to haul a generator ( and lots of reasons not to ...). We don't all do this based on the same objectives.
If you have no solar and are running stock batteries and like to be off grid and a "smart control" trailer ( yes a lot of and's ...) then running a generator may be a daily sort of thing.
If you have monster solar and carry a generator for that one in a thousand "just in case" string of very cloudy days, you may never actually use the generator at all, let alone on this or that trip.
If you are one of the hardy few that camp a 4 hour drive from the nearest fuel supply, that eight hour round trip is going to be a factor.
If you are off grid right now in the middle of the country and *know* you will be running both of the A/C's every day / every night for the next two weeks, you either need a whole bunch of fuel cans or a full time driver to do fuel runs.
Lots of variables and lots of very different use cases. No one easy solution that fits all of them.
Old 07-26-2021, 04:04 PM   #19
Glen Carter's Avatar
2018 19' Tommy Bahama
Rancho Santa Margarita , CA
I use a Eagle 5 Gal can. Just finished a 3 week trip with it and the Honda in the back of my Cayenne. I put each one in a black trash bag and never had any sense of gas odor during the entire trip.
https://www.eagle-mfg.com/type-i-ste...ter-red-ui50fs
Glen Carter is offline   Reply With Quote
Old 07-26-2021, 04:50 PM   #20
2021 27' Globetrotter
Daytona Beach , Florida
I have 2 of the 5 gals. Great cans.
I also carry a Surecan, another nice product
Wow, thats a small can. I swear it's bigger,,,,,,,maybe not.
nitzo is offline   Reply With Quote
What do you carry in your truck and how do you organize them? Airperson Boondocking 45 11-07-2011 11:42 PM
Where do you start? First Genny, First Rally stowaways Generators & Solar Power 15 08-16-2010 11:21 PM
What do you carry in your AS? jmichaelr Our Community 22 06-08-2009 05:08 PM
Poll: Do you carry a spare for your trailer? Garfield Tires 38 02-18-2008 07:55 AM
How often do you use your genny? gowyn Generators & Solar Power 26 02-13-2008 07:25 AM
