Old 02-03-2020, 07:57 AM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
What size wire for solar internal connections?
So I'm still building out my solar setup. One thing I omitted to order was all the internal wires!
- Will use the factory solar wires for connecting to the Victron controller
- NEED: Controller to switch, also output of switch
- NEED: In/out of 60A breaker (600W system)
What size to get? Should I get individual pieces with 3/8 rings? Any handy amazon links?
Thanks!
Kalashnikov is offline   Reply With Quote
Old 02-03-2020, 11:34 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
4 AWG for 600 watts to/from the controller assuming your are running those panels in parallel.
wulfraat is offline   Reply With Quote
Old 02-04-2020, 08:47 AM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
The Victron 100/30 and 100/50 controller connections are designed to fit 6 AWG. If you get 4 AWG, you will need to trim some the connection area to fit the 6 AWG connections - not a big deal. There won't be much difference using 6 or 4 awg over a couple of feet at <50A. I just used 6 AWG from the controller output, to the breaker, and on to the busbars. I used the factory prewire 10 AWG from the roof, through the switch, and into the Victron controller. Here's eight detailed pictures showing my connections between the Victron controller, switch and breaker used on both my Airstream installs using the factory prewire: https://www.airforums.com/forums/f44...ml#post2167314
Notice to connect to the busbars, I used these: https://www.lowes.com/pd/Blackburn-2...r-Lugs/4582297 because the 6 AWG would not fit into the busbar connections.
2021 Northern-Lite 10-2 & F350 DRW PSD, 380W Solar/Victron/600A BattleBorn
0 nights 0 miles
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 02-04-2020, 11:10 AM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
#8 marine grade strand or better
AS installs #10 which is a very minimal for a single panel
#4 or better allows for lower loss and greater run lengths
google cable tables and you will see loss/ft based on wire size
waninae39 is offline   Reply With Quote
Old 02-04-2020, 12:21 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I install 4AWG
Old 02-04-2020, 12:33 PM   #6
AirMiles's Avatar
Minimal for one panel? Baloney! The 10 AWG solar prewire is just as capable with 600W configured in series-parallel as 600W configured in parallel on 4 AWG. I've been demonstrating this fact using 400W of panels for 250 days of use over the past two years with real-world performance on the "Solar Show & Tell" thread. https://www.airforums.com/forums/f44...ll-181608.html
For those interested, I've calculated the voltage drop for 600W of series-parallel configured panels and provided links to the calculations here: https://www.airforums.com/forums/f53...ml#post2208101
By my calculation . . . this configuration would be capable of producing 588 watts to the controller for a total loss of only 2.0%."
I've since upgraded to a 27' Airstream and will be demonstrating how 600W of panels works on the factory prewire in the Solar Show and Tell thread this summer. To date, the best day of production was 2kWh with 1/2 day of overcast skies and the maximum wattage in late November was 491W. I expect that these numbers will be dwarfed by production this summer with longer solar days, higher sun angles, and clear summer skies. So stay tuned to the "Solar Show and Tell" thread to see how 600W on the Airstream prewire works.
0 nights 0 miles
Old 02-05-2020, 06:47 PM   #7
I already pulled the trigger on a bunch of 4awg cable based on wulfraats's reply. Would have bought 6awg if I had seen Airmiles' post in time.
This is for the wiring between the cluster of components related to solar inside the camper, not for the panels->controller.
Oh well. I'll trim the wires to fit.
Old 02-06-2020, 07:26 AM   #8
gator.bigfoot's Avatar
KW , Ontario
You won't regret the 4 awg. The lower the voltage drop the better. I prefer to have less than 1% in losses. Even 3% is too much IMO. On my install I needed over 50 feet of it.
Make sure you use proper connectors/crimps for it though. You don't want to increase your resistance after you through the effort of adding the better wire.
gator.bigfoot is offline   Reply With Quote
Old 02-06-2020, 08:42 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
#4 is the safer choice. Some types of #6 are not rated for 60 amps under some conditions. You want the wire to be rated at, or higher than the breaker protecting it.
Al
Old 02-06-2020, 07:45 PM   #10
wulfraat's Avatar
#4 is the correct gauge for your application and equipment if you want to adhere to amperage ratings of the cable / equipment.
It is especially important to have the correct gauge when you a pulling some length, this is not a 2 or 3 foot run.
Welcome to the wonderful world of solar and congrats!
Old 02-07-2020, 04:50 AM   #11
Is it not just a couple feet? I bought 6ft of red/black each just in case. Haven't opened up my AS yet, will complete all the exterior work first as weather permits.
Expecting:
[Prewire]-10awg->[Controller]-4awg->[Switch/breaker]-4awg->[Bus Bar]
Size wire for future solar rugjenkins Generators & Solar Power 5 04-25-2016 01:35 PM
Wire size for 90 watt portable solar Trailbob Generators & Solar Power 5 02-27-2016 09:10 AM
Internal 110V wire placement dominicjohn General Repair Forum 2 09-16-2015 02:20 PM
Tow wire connections mrrealtor 1970 - 1973 Sovereign 5 03-21-2015 06:52 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
