11-15-2014, 10:26 AM
2015 27' FB Eddie Bauer
Centre Hall
, Pennsylvania
What generator should we buy?
We just purchased our first AS (yahoo!) and would very much like suggestions on a generator. Thanks in advance! Lucy and Bill Curran
11-15-2014, 10:48 AM
2002 31' Classic
Monroe
, Iowa
I have a Honda and a Yamaha tri power. The Yamaha runs on gasolene, nat. gas, or propane. I like the Yamaha the best.
Go to motor snorkle.com They've got 'em all, and their prices are pretty good
11-15-2014, 10:51 AM
2009 23' FB Flying Cloud
Canmore
, Alberta
Very oft- discussed subject here. View the threads below or search 'generator'.
11-15-2014, 11:11 AM
Tampa
My two cents:
In my job we used Honda 300 iS's. We had about 25 and we used them all, four days a week, 15 hrs a day. I loved them. QUIET!
Reliable, start with a key, stable enough for electronics, ran about 8-10 hrs on a tank.
I tried to buy a used one when they replaced them, but a reseller bought all of them.
The downside? They're heavy. I might muscle one out of a flatbed, but not muscle it back in. Two people easy.
I'll buy one.
11-15-2014, 11:26 AM
2012 25' Flying Cloud
Berlin
, Maryland
I have two Honda 2000's. One does most everything I need and two together works the AC and everything else. I like the 2 small ones because one person can lift them in and out of the truck, Not sure I want to lift a bigger one at my age.
I also understand the Yamaha's are as equally as good so I don't think you could go wrong with either make. Not familiar with the other brands.
11-15-2014, 11:29 AM
Canmore
, Alberta
My vote as well.
11-15-2014, 01:45 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use a pair of Honda 2000's that we have had for seven years. They are light (40#) quiet and powerful. I can run the Airstream on one if I'm not using the air conditioner. Running the two in tandem easily handles the AC. I am currently considering going to a Honda 3000 and mounting it in the bed of my truck.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-15-2014, 04:06 PM
1989 29' Land Yacht
Mesa
My vote is 2 Honda 2000.I have boondocked with just one for years.Since I stay away from areas where I need AC.
BUT I just got a new microwave oven that takes more power than my one gen.can put out so I may get another 2000.Most of the time I just store bread in the microwave.
I like that at 80 I can still move it and I have more options storing it.
Why run a larger gen when you do not need the power, your fuel use is higher and it is hard to move around and store unless you mount it in your truck.I sure a SUV to tow so can not put inside it.
I did just get a 190 watt solar panel that keeps my batterie's charged so I do not have to run my gen.as much.I have the panel on a 30 ft wire so I can move it around to get the best sun use.I also have a small inverter so I can run small 115 ac items like TV,computer and chargers for phones ect it ok put will upgrade to a larger on someday
Live every day as if it is your last one and one day your going to be right.
11-15-2014, 06:17 PM
1994 21' Sovereign
The high country. Black Mountain range.
, North Carolina
We have a Yamaha EF2400ishc. I cannot say which generator is best because I have not used them. I can say that the Yamaha has performed flawlessly and quietly. It also runs our air conditioner. Weighs about 75 pounds.
WBCCI 28499
"Not all those who wander are lost" J.R.R. Tolkien
11-15-2014, 07:14 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
The questions you need to answer are what do you want to run with the generator, how do you want to carry it, and are you happy with one that runs on gasoline?
Then it is pretty much a matter of picking which Honda or Yamaha you want and do you want it on propane or gasoline.
11-15-2014, 07:34 PM
Spokane
Get a Honda or a Yamaha. My Honda 2000 has been trouble free for 7 years but I have a friend with a Yamaha and his is doing well too. Stay away from the cheap loud things. I know someone who purchased a Honda look a like for half the price. It is quieter than the construction types but by the sound of it, the feel of it and how it turns over, I wouldn't bet a lot of money it will last as long as the two mentioned above.
11-16-2014, 11:10 AM
2013 31' Classic
billings
, Montana
Amen to honda,very trouble free....
11-16-2014, 11:14 AM
2011 34' Classic
Calgary
, Alberta
Honda's EU2000i is hands down the lightest, most compact... for AC, should you wish to use, two are required.
In our RV Service business, we have used the Yamaha 2400's (inverter) for everyday over the last 5 years... there hasn't been one AC we couldn't run. Light enough to transport without a hernia. No electric start if that is important to you.
Tony
11-16-2014, 11:27 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Camping World has a carry bag for the Honda 2000 series with wheels, so it is even easier to move it around once on the ground from the truck. It also disguises what is inside to help reduce the theft impulse when the units are in the truck bed under the camper shell.
http://www.campingworld.com/search/i...y&Nty=1&Ntpc=1
We have the primary and Companion 2,000 watt units
11-16-2014, 11:31 AM
2012 25' FB International
Trent Woods
, North Carolina
How many times do we need to see the same thread on what generator to use????
Larry
11-16-2014, 11:36 AM
Tampa
Larry
Just one more.
11-16-2014, 11:48 AM
2014 31' Classic
Apache Junction
I noticed the OP who created this thread was doing his first post. Perhaps some slack is in order plus an explanation on how use the search feature and other aspects of the forum:
http://www.airforums.com/forums/f368...ers-19484.html
11-16-2014, 12:43 PM
2010 20' Flying Cloud
Hailey
, Idaho
Honda 2000's! Reliable, quite and, unless you need the AC, I just pack the companion model and leave the other 45lbs at home. This is not a slam against Yamahas, I have just been completely satisfied with the Honda 2,000s. Jon
11-16-2014, 03:11 PM
1958 22' Caravanner
Plattsmouth
, Nebraska
I have 2200 watt dual fuel at 142 pounds mounted on the tongue of a 1958 22' Caravanner. Handles everything. It handles 20 amps continuous so I can run my house
window a/c and induction hot plate at the same time.
01-23-2015, 07:06 AM
2015 27' Flying Cloud
maple grove
When I'm dry camping I don't use my microwave or air conditioner. So I purchased a yamaha 1000 which is very light and quiet. I also purchased one of the new 15 amp electronic chargers from Wal-Mart for about $50. It only weighs a couple of lbs. Now when I dry camp and need to charge my battery, I hook the charger to the battery, start the generator and enjoy my coffee.
