11-08-2020, 04:22 PM
2014 25' FB Flying Cloud
Albany
, Oregon
Victron Multiplus Compact
So when I ordered new lithium batteries from Battle Born, they suggested the Victron Multiplus Compact Charger/inverter. I "wrongly" assumed that it was, in fact, compact. I looked at the size specs of every other thing I bought, except that. After opening the packages I found that it's not only NOT compact, but 20.5" high! I'm trying to figure out where to mount this sucker or simply send it back and get a different unit. Has anyone bought one of these for their trailer? I have a 2014 25' Flying Cloud FB. I have relocated the batteries under the bed and could probably fit this thing lying on it's side, but not sure that's a good idea. Any thoughts for mounting and/or ideas for another type of converter/inverter?
I also bought a BMV-712 battery monitor and the Orion-Tr Smart 12/12 30A DC/DC charger.
I already have 2 Zamp (90 Watt) solar panels on the roof and a Zamp ZS-30A controller on board. Will be adding another 180 watts soon.
11-08-2020, 04:31 PM
2017 30' International
Broomfield
It sounds like you ordered the Multi 2000.
You want to return that and get the 3000. Aside from giving you 50% more inverter power, the 3000 will fit under your bed close to the batteries.
Mine is placed on the outside curve and I can still get - bin in the storage area.
11-08-2020, 06:08 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Yep you ordered the 2000watt MultiPlus
11-08-2020, 06:24 PM
2012 Avenue Coach
Corpus Christi
When I was shopping the 3000W Victron Inverter/Charger I found different dimensions on different sites. Do you have exact measurements of the Multi 3000 12V model (including any mounting flanges)? Thanks.
11-08-2020, 06:35 PM
Broomfield
You want the 12/3000/120. There is only one cabinet size for the good old MultiPlus 3000.
https://www.victronenergy.com/upload...120V-US-EN.pdf
14.3 x 10.2 x 8.6 inches are the exterior dimensions.
You can see from my photo how it can be mounted under the bed.
It can also be placed in the trunk, center isle, side area like mine, or however you like but clears the bed just fine. Orientation does not matter either - Upside down, on its side, etc..
Just make sure the fan on the bottom has access to some airflow.
11-08-2020, 07:54 PM
2012 Avenue Coach
Corpus Christi
Thanks. The Victron would have fit my application, but I wasn't sure at the time because it looked too wide and (as stated previously) I was unsure I could trust the various dimensions I saw on-line. So I ended up with a Renogy that has served me well for the past year, but it was a tight fit because their stated dimensions did not include the mounting flanges (and additional 3/4" in width) and did not include their wire gromets (an additional 1' in length).
The available space in my class b is extremely tight and every inch counts.
11-08-2020, 08:02 PM
Broomfield
Ah. Yes, Interstate is an interesting challenge.
11-08-2020, 08:39 PM
Albany
, Oregon
Thanks for everyone's input. I'll be ordering the 3,000 in the morning.
11-08-2020, 09:40 PM
2022 25' Flying Cloud
NCR
, Ontario
we have the MultiPlus 3000. it does easily fit under the bed
11-08-2020, 10:17 PM
Broomfield
Make sure to also get the digital multi control for the 3000........
https://www.victronenergy.com/panel-...ntrol-panel-gx
