Old 05-24-2020, 04:23 PM   #1
FishByFly's Avatar
2017 25' Flying Cloud
Fort Worth , Texas
Victron History Help
We were out a few weeks ago for the first time really monitoring our solar setup. All seemed fine and we were pleased. On our return and upon reaching our storage, I did one last look at the Victron App. The system showed all “0” even though we had been in full sun all morning before departing and drove four hours in full sun. I was perplexed but didn’t think much of it.
Went to storage on Friday and opened the app. It asked for software upgrades so I let the system downloaded. Had the same “0” readings and the “history” had not progressed since my trip two weeks earlier.
Went to storage today, and again not update on the history. Same as it was over two weeks ago.
Thoughts? Suggestions?
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - “Fly Fish Inn
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 05-24-2020, 04:57 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Do you have a disconnect switch that is in the off position? Have you checked that all cables are connected and tight? It would certainly appear that the panels are not delivering current to the MPPT controller....
It’s showing battery voltage (seems to have been drawn down) so that is good and would point you toward the wiring / disconnect switch between the controller and the panels.
wulfraat is offline   Reply With Quote
Old 05-24-2020, 06:38 PM   #3
FishByFly's Avatar
Fort Worth , Texas
No disconnect that I’m aware of. I checked out the SmartSolar MPPT 100/20 and it shows a flashing blue light on the Bulk. I do have breakers on both the panel circuit and battery. I switched off and back to reset.
The item that initially triggered my concern is the “history” tab. The “today” reading is from more than two weeks ago. Shouldn’t the time still run even if the solar panels are not supplying power?
FishByFly
2010 F250 Lariat
Old 05-24-2020, 08:12 PM   #4
wulfraat's Avatar
Yes time should march on if h controller is connected to the battery and live.
Have you tried connecting via Bluetooth and Victron Connect app to verify that it is delivering amps to the batteries?
Old 05-24-2020, 08:24 PM   #5
FishByFly's Avatar
Fort Worth , Texas
That screenshot is from the app connected via Bluetooth
FishByFly
2010 F250 Lariat
Old 05-24-2020, 10:06 PM   #6
wulfraat's Avatar
Understood but what is the real-time view showing you when the sun is out?
Old 05-25-2020, 06:58 AM   #7
FishByFly's Avatar
Fort Worth , Texas
I’ll have to pull my trailer from covered storage...once the sun come out.
FishByFly
2010 F250 Lariat
Old 06-01-2020, 02:27 PM   #8
FishByFly's Avatar
Fort Worth , Texas
Ok. Issue resolved. Some time on our last return trip, the panels got disconnected from the Factory roof box. Plugged them in and all seems well. Cloudy day with 2 100w panels.
Has anyone had issues with panels coming disconnected? Is there a need or way to improve this weak link?
FishByFly
2010 F250 Lariat
Old 06-01-2020, 03:34 PM   #9
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
You can add a zip tie stick on mount near the connection. Mine have never unplugged in tens of thousands of miles with a similar mount to these: https://www.amazon.com/dp/B06XNBS6TG..._Fnx1EbF4P4V5Y. You may want to use 3M VHB tape to stick them to the roof.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Victron upgrade Help please Life is a Highway 2016 - Current Flying Cloud 10 06-22-2019 07:26 AM
Help with Victron Lithium Install Troutboy Batteries, Univolts, Converters & Inverters 39 05-06-2019 10:14 AM
Help with brand new Victron dznf0g Electrical - Systems, Generators, Batteries & Solar 2 05-04-2018 12:17 PM
Setting up a Victron 700 help Dragline Electrical - Systems, Generators, Batteries & Solar 8 07-06-2017 01:32 PM
Help with the history of my Overlander Mulligan 1970 - 1973 Overlander 1 05-21-2013 12:51 PM
