03-05-2021, 05:43 PM
Moss Point
, Mississippi
Victron Digital Multi Controller using old 1K Inverter wire
The Victron DMC uses an RJ45 cable (4 pairs) to connect to Multiplus. I would like to put my DMC where the old 1k Inverter control is located on wall between sink and stove. However, the old Inverter control has just an RJ11 cable (2 pairs). Has anyone tried to use the existing 2 pair to control the DMC? Seems impossible to use the existing 2 pair cable to pull up a new 4 pair wire....
Thanks, Dave
03-05-2021, 05:49 PM
2007 22' International CCD
Corona
There are RJ-45 to RJ-11 adapters. Look on Amazon
03-05-2021, 06:14 PM
Moss Point
, Mississippi
Thanks, but question was if 4 wires (2 pair) that already is in place could be used to connect the DMC. I can add 2 pairs to RJ45 connectors or use adaptor.
Amazon support (?) said it is not possible. Just thought the AS community might have discovered some info or tried it since all the new AS's have the 1k inverter switch and going to Multiplus would make sense to try and add the DMC to spot of the old Inverter switch.
If not possible, I'll have to mount DMC somewhere, probably on side of lounge base.
03-05-2021, 06:36 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
It will not work....but, you can use the existing RJ11 inverter switch cable to pull a new piece of Cat-5 cable in the wall. I do it all the time.
03-05-2021, 10:33 PM
2018 30' Flying Cloud
Anchorage
, Alaska
There is a spare RJ45 in the wall, behind the inverter control - at least on mine. I did the swap you’re talking about and no fishing of wire was required. Just unplug the RJ11 from the old control and plug the RJ45 into the new one. You also have to cut the hole bigger.
03-06-2021, 05:15 AM
Moss Point
, Mississippi
Ronnie and AKNate - THANK YOU!! There is hope. I will look for the spare RJ45 and if not I'll try Ronnie's fasten and pull! Really is the best place for mounting the DMC so glad there is a way forward. AS at the shop, so will follow up when I get it back with outcome.
03-06-2021, 07:35 AM
Naples
It is relatively easy to pull a new RJ-45 thru a small hole cut into the bottom of your wall directly below the location of your new controller. It is very important to make your hole as close to the underside of the counter as possible, as there is a horizontal support beam just below that location.
It's very easy to do!
lewster
03-06-2021, 08:53 AM
Moss Point
, Mississippi
Thanks! With 3 possible solutions I'm confident I'll get this where I want it to be. Love this forum and the help that is available!
Dave
03-06-2021, 10:14 AM
2020 27' Flying Cloud
Tampa
If you have the zamp solar or maybe have the zamp prewire in the wall it is rj45. I replaced my zamp charger with the victron solar and used the zamp rj45 wire for my multiplus control. I also mounted the GX color control by pulling the color control wire from underneath the counter.
