Old 10-28-2018, 06:51 PM   #1
Journeyman
2016 25' International
Amherst , Massachusetts
Victron 712 Problems
Gang,
I have a Victron 712 battery monitor and shunt... and it's totally given up the ghost. I replaced the electronics unit (thinking the unit must be bad) but the replacement unit is also showing no joy.
Batteries have charge and other parts of the system are working great. Charge monitor died while the trailer was sitting in my driveway for an extended period, so it aint like something rattled loose.
Any ideas how I should troubleshoot this?
Thanks!
--Thiel
thiel is offline   Reply With Quote
Old 10-28-2018, 07:04 PM   #2
"Cloudsplitter"
"electronics unit"?
Shunt or Monitor?
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Old 10-28-2018, 07:29 PM   #3
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
I'd call Victron. Maybe the positive connection to the shunt has come loose? Doubt it is the monitor.
billrector is offline   Reply With Quote
Old 10-28-2018, 08:34 PM   #4
Journeyman
I replaced the head unit but I have not replaced the shunt.
I checked all the connections on the shunt. Tight as a drum.
I also disconnected and reconnected the positive lead (temp sensor) to see if that would "reboot" it, but no joy.
One last detail: I discovered that the monitor was dead at the same time that I found my batteries had dropped down to a little lower than 50%—the lowest discharge I've ever had. (Days of rain prevented the batts from recharging all the way.) Everything in the trailer was working fine (e.g. lights not dimming) except the fridge shut off from low voltage.
Old 10-28-2018, 08:47 PM   #5
"Cloudsplitter"
You may have started the diag at the wrong end...I believe the shunt would be the more likely culprit.
Did you have a voltage reading at 50% SOC.
On the first test I did with the BB's the SOC got to 50% with out effecting the fridge.
Old 10-31-2018, 08:55 PM   #6
Journeyman
I had a voltage reading from the trailer's in-built monitor, but the Victron had already gone dark. (And yes, I know the trailer's monitor is not accurate... I'm guestimating the 50% based on my experience with that monitor and, perhaps, a bit a wishful thinking. It was reading 11.9 and under load in the cold.)
I have been thinking that replacing the shunt is my next step. Slightly annoyed that it (likely) has given up the ghost so soon after installation.
Old 11-01-2018, 05:58 AM   #7
"Cloudsplitter"
Where did you purchase? How long ago?
I got ours from Amazon, just for the return option with Prime.
Victron has a pretty good C/S reputation, call see if they would send a replacement...BUT, it would not be unusual if returns are restricted if it was a DIY install. 🤨
Victron BMV 712 setup wareaglewalt Batteries, Univolts, Converters & Inverters 17 02-10-2020 07:39 PM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Victron 712 install in 27' FB Philip Jones Batteries, Univolts, Converters & Inverters 22 03-18-2018 03:20 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
