03-11-2020, 08:12 PM
2019 28' Flying Cloud
Dripping Springs
Victron 100/50 controller did not wake up
So I got my 600W solar system all wired, flipped the switch - nothing!
It was pretty late, the sun had almost set. Could it be that the system just didn't generate enough voltage to kick-start the controller? The Bluetooth app showed 0V. On the controller the "Bulk charge" was blinking blue every few seconds.
I'll be at work tomorrow so there will no good time to observe it during the day. Ugh.
03-11-2020, 08:49 PM
2017 22' Sport
NCR
, Ontario
"it was pretty late, the sun had almost set."
not enough light, report again mid day with no clouds
this is VERY common with solar
03-12-2020, 03:45 PM
Dripping Springs
Still nothing, plenty of sun
Does the storage mode matter?
03-12-2020, 03:46 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Yes it should not be in storage mode.
03-12-2020, 04:24 PM
Dripping Springs
Didn't make a difference, storage mode or not
*sigh*, guess i'll start debugging. I'll start with the panels and see if I'm getting voltage. Work my way down to the controller. Ugh.
03-12-2020, 04:37 PM
Dripping Springs
All 3 arrays putting out 38v into the rooftop Zamp combiner
Noticed one thing: the victron controller blinks blue regardless of the setting of my Blue Sea switch! (On or off)
03-12-2020, 04:59 PM
Dripping Springs
Confirmed that 38v is reaching the Blue Sea switch from the roof
Confirmed that Blue Sea puts out 38v
Confirmed that polarity is as expected: Yellow PV is positive, Green is negative
Stumped!
03-12-2020, 05:52 PM
2018 27' Globetrotter
Apollo Beach
Did you connect to the batteries before flipping the solar switch on? The solar controller needs to read the battery voltage first before the solar is activated the first time to set 12V. A screen shot of the status screen on your phone would help. A screen shot of the settings/battery screen would also help. You can disable/enable the charger from the battery screen. The Victron 100/50 should charge no matter the position of your store/use switch.
2021 Northern-Lite 10-2 & F350 DRW PSD, 380W Solar/Victron/600A BattleBorn
0 nights 0 miles
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-12-2020, 05:55 PM
Apollo Beach
That's because its connect to the batteries.
0 nights 0 miles
03-12-2020, 05:56 PM
Dripping Springs
Yes, I connected the entire system from the bottom up - battery to controller, then the panels
Dead as a doorknob
03-12-2020, 05:59 PM
Apollo Beach
Battery side is working, no voltage coming from solar panels. There's got to be a problem between the switch with 38V and the solar controller input connection.
State: off - is it dark outside? Still should be seeing voltage from the solar panels on the status screen I believe.
0 nights 0 miles
03-12-2020, 06:02 PM
Dripping Springs
03-12-2020, 06:03 PM
Apollo Beach
Charger is enabled. Just missing voltage from panels???
0 nights 0 miles
03-12-2020, 06:04 PM
Dripping Springs
Sun went down, I'm done for the day. Need a couple drinks after this
Apollo Beach
Can you check the voltage at the Victron solar controller inputs? By probing into the inputs while leaving everything connected?
0 nights 0 miles
03-12-2020, 06:07 PM
Apollo Beach
I would focus on the solar controller input connections. If there's voltage there, it could be a bad solar controller.
0 nights 0 miles
03-12-2020, 10:05 PM
Paradise
If you bought the controller from Amazon, message seller, get another.
Or, you might have a wire strand crossing paths at the controller.
If that checks out, I would definitely be worried about charge controller.
03-12-2020, 10:20 PM
2017 22' Sport
NCR
, Ontario
my first victron solar controller was bad. it was swapped. now working fine for 2 + years
03-13-2020, 05:08 AM
Dripping Springs
Will double check by probing the inputs.
Really hope it's not the controller, I have a big trip planned and there's little time to find another.
The crossed strands is a possibility. Some of my wires are 6awg, a little too fat for the controller.
Amazon has plenty of 3rd party vendors but I'm not seeing any with overnight shipping. I need one NOW! Closest dealer is three hours away (6hr round trip.)
03-13-2020, 05:45 AM
Dripping Springs
It's still pitch dark outside but I went to the trailer and checked for crossed wire strands - it's totally ok.
I ended up finding another on Amazon when searching only for "Prime" items (I don't even have Prime), paid $9 for shipping and it's supposed to arrive today.
Fingers crossed!
