Old 08-04-2020, 06:09 PM   #1
2020 20' Bambi
Clayton , North Carolina
Victron 100/30 vs Victron 100/20?
Ok, if I add another Zamp 90W solar panel to the roof of my new Bambi (to have 180W), I know I can easily get by with the 100/20 to replace the Atkinson stock unit. I have a portable Zamp 180W suitcase as well and might consider wiring the Zamp umbilical to the charge controller instead of directly to the battery (as is stock). In which case seems the 100/30 would be more suitable. But say I buy the 100/30, install and use with the 180W rooftop and then never rewire the umbilical directly to the inside charge controller. Is there then a downside to having the 100/30 just for the 180W rooftop? Other than fact I will have spent about $50 more for it? Is there a mechanical/electrical downside? thx, stephen
smsasf is offline   Reply With Quote
Victron 100/30 and Victron 712 installer needed in PA RMD Generators & Solar Power 0 07-01-2020 09:08 AM
Victron 100/50 controller did not wake up Kalashnikov Generators & Solar Power 76 03-19-2020 02:53 PM
Victron MPPT 100/50 went to float too soon? Omnial Generators & Solar Power 5 09-20-2019 11:02 AM
2 AGM Batteries, Victron 100/30 and 1500 Watt Vertamax Pure Sine Inverter under Dinet JMB11 Batteries, Univolts, Converters & Inverters 0 02-28-2019 04:14 PM
Unable to reconnect to Victron 100/20 marter Generators & Solar Power 41 10-13-2018 05:35 PM
