Old 04-04-2020, 01:30 PM   #1
2020 25' Globetrotter
Malibu , California
Victron 100/30 bus bar wire size
Forgot to uninstall my Victron MPPT controller wires to bus bars when I moved up to 25 GT. What size do I need, #6? 400 watt panels
Garfish is offline   Reply With Quote
Old 04-04-2020, 01:39 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I used 6 gauge for my Victron 100/30.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-04-2020, 01:55 PM   #3
2018 25' International
Slidell , Louisiana
#6 AWG will have a maximum of 0.27 Volts (9.2 Watts) lost in 20 feet, while #8 which is also allowed will have a maximum of 0.45 Volts (15.3 Watts) lost.
Brian
Old 04-04-2020, 02:28 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
You “can” get 4AWG to fit, but 6awg is recommended.
Old 04-04-2020, 04:02 PM   #5
Malibu , California
Now, the bus bar
Was pretty easy to put in 22 Sport. The 25 GT has a lot more to sort through. Inverter, DC box under cover and lots of wires. Guess I will open the DC box to see what’s there. Was going to install the 712 at the same time but looks like I need both neg batteries cables connected on one side of shunt and connect two on the other side one going to neg bus bar and other to inverter
Old 04-04-2020, 04:54 PM   #6
Malibu , California
Bus bar exposed
So, where do the controller to bus bar wires go? Left bar is positive so positive wire connects to one of the open bolts on left of that bar? And neg bus bar looks like two open on bottom but also see open connections on top of grey part. But that also has wires going to POS bus. Confused
Maybe just run wires out and connect directly to batteries?
Old 04-04-2020, 07:44 PM   #7
Slidell , Louisiana
So you can land the positive on any of the open lugs on left side of the left (pos) bus as you suggested. The batteries will be charged through the breakers protecting the battery cables. The negative/ground bus is lower right and there are a couple lugs open again as you noted. The Grey terminal blocks have continuity horizontally but vertically only if a red insertion bridge is present so there is one negative available on the left second from the bottom, but the negative return to ground bus is too small to use that one. the Black (left third from bottom) is a ground wire grounding the positive bus metal mounting bracket.
Summary use the two bus bars directly, don't mess with the grey terminal blocks.
Brian
Old 04-05-2020, 04:59 AM   #8
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Here is where I connected my solar controller positive and negative outputs with 6 gauge wire. I used these connectors available at Lowe's: https://www.lowes.com/pd/Blackburn-2...r-Lugs/4582297
Name:	Solar Connection1.png
2018 GT27Q, 45 nights 9,860 miles, 600W Solar - Produced 75kWh, PD4655L, 6V Batteries, Champion DualFuel, ProPride&BOSP, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, 400W Solar - Produced 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(To RF)
AirMiles is offline   Reply With Quote
Old 04-05-2020, 09:26 AM   #9
Malibu , California
Lug nuts
So, that’s how you connect. Looked like 6 gauge would not fit otherwise
Old 04-05-2020, 09:36 AM   #10
Malibu , California
Shunt
AirMiles, did you happen to install 712 too? If so please send pic. Thanks
Old 04-05-2020, 01:49 PM   #11
Hotfoot
2002 25' Safari
Santa Ana , California
in your pic there are 2 heavy gauge red wires going to breaker, are these the battery feeds?
So to disconnect 12 volts from the distribution you can turn off these 2 breakers? If so I'd want mt solar DC feed on the supplying the batteries. this allows battery filtering, one source for disconnect and while disconnected charging batteries.
hotfoot88 is offline   Reply With Quote
Old 04-05-2020, 01:57 PM   #12
AirMiles's Avatar
No I did not install a BMV-712. I installed a Victron Battery Smart Sense module instead. This module provides voltage and temperature compensation which is important for your wet-cell batteries. It just connects inside the battery box and uses bluetooth to communicate back to the Victron Solar controller. With wet cell batteries, voltage is a good indicator of state of charge. Just use and abuse your Duracell EGC2 batteries because they are tough. Don't worry about deeply discharging them because they are designed to be discharged by 80%. I've abused my Duracells for over 250 days with very deep discharges and they still test and perform as new.
(To RF)
Old 04-05-2020, 02:24 PM   #13
Malibu , California
Ordered. Easy
Old 04-05-2020, 05:39 PM   #14
Slidell , Louisiana
One is the battery feed, the other is the main going to the power distribution center.
The breakers are self resetting thermal breakers. You can't manually turn them off. They reset by cycling power (disconnecting the battery). You don't really want to put your solar directly to the battery without a fuse/breaker. More accurately, it is against code and best practices to do so. So per the code, land your solar after the thermal breaker or on less fancy models, fuse.
Brian
Old 04-05-2020, 06:06 PM   #15
Hotfoot
2002 25' Safari
I'm sure there is supposed to be protection on each solar panel line wherever you feed it too, I just think it best battery side of wiring
Old 04-05-2020, 07:10 PM   #16
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Garfish,
Connected directly to the batteries positive side (through the fuse) and to the on the downhill side of the shunt on the negative side.
DaveP
Old 04-06-2020, 05:12 AM   #17
Slidell , Louisiana
Hotfoot88, as I tried to explain, the thermal breaker protects the battery cable from over current. If you connect a new source or load on the battery side of the breaker, even one that is fused, it is possible to exceed the ampacity of the battery cable. For example, if the breaker source is sending max current (say from the converter) and the solar system is sending max current at the same time. For this reason it is against the NEC code to do what you suggest.
You could connect the solar charger directly to the battery with a new dedicated fused cable, but it would be redundant and would only gain you about 3 watts while charging.
Brian
Old 04-06-2020, 11:46 PM   #18
Hotfoot
2002 25' Safari
BayouYour injecting another supply down stream from primary source. Usually doing it right takes a little extra time but usually worth it
Your relying on your battery bank all night and most efficient way to utilize solar source to replenish is at batteries.
Old 04-07-2020, 05:51 AM   #19
Slidell , Louisiana
I understand what you're saying, but by that logic the converter would also have dedicated wiring directly to the batteries. I would think following NEC recommended practices would be considered doing it right, perhaps not....
Brian
Old 04-11-2020, 06:00 PM   #20
Malibu , California
30/100 and 712 in
Finished both and only weird thing was ring terminal crimp for inverter neg cable. It is #4 so I bought #4 ring terminals but they were too large and would not crimp (hydraulic). The #6 I got for the battery cable was a fit for both 4 and 6 and so that’s what I used. Everything tight and love the Bluetooth
ID:	365527   Click image for larger version
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
DC Bus Bar Box - Question - Loose bar free in box JennyJakeNH Electrical - Systems, Generators, Batteries & Solar 1 07-16-2019 05:37 PM
Victron VE Bus Smart Dongle lsbrodsky Batteries, Univolts, Converters & Inverters 18 07-02-2019 08:28 AM
Victron MPPT grounding wire size? Mx468 Batteries, Univolts, Converters & Inverters 8 05-22-2019 11:57 PM
2005 Airstream Skydeck - Hospitality/Party Bus - NASCAR Tour Bus eBay Watch Airstreams on eBay 0 01-13-2012 10:00 AM
2005 Airstream Skydeck - Hospitality/Party Bus - NASCAR Tour Bus eBay Watch Airstreams on eBay 0 01-06-2012 08:00 AM
