Old 07-14-2020, 11:09 AM   #1
2021 16' Caravel
Kirkland , Washington
VHB and mounting bracket size
Hi all,
I have been researching rigid solar panel for my Caravel 16'. It seems like the only panel that fits the limited roof space is Zamp 90w slim. After reading many posts here I have decided to do a VHB + sealant install without drilling.
https://www.zampsolar.com/90watt-long
Note the mounting bracket is different than Am solar's VHB bracket
https://amsolar.com/rv-mounting-accessories/91m-35ms
I am wondering if Zamp's brackets' feet are too small for VHB to get a secure bond? Has anyone had experience with these brackets?
Also part of the roof is painted white, so the VHB would have to bond to the paint instead of aluminum sheeting. Is that a problem?
Thanks!
hovr is offline   Reply With Quote
Old 07-14-2020, 11:40 AM   #2
1972 23' Safari
Middletown , Rhode Island
Originally Posted by hovr View Post
Hi all,
Thanks!
Hi hovr, I just completed doing this so while its fresh on my brain, here's what I did. I used renogy brackets which were smaller than am solars, I used 4950 vhb tape to bond to roof and sikaflix over each brackets foot. I covered the brackets with a garbage bag for about 3 days because I'm parked under trees in my driveway, nothings worse than having twigs, leaves in your nice new sikaflix Those brackets are going nowhere. I would scape or remove paint from where you plan on placing each bracket/foot, then make sure the area is cleaned thoroughly, I used rubbing alcohol. Good luck!
Mx468 is offline   Reply With Quote
Old 07-14-2020, 12:01 PM   #3
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
When I had my Zamp panels put on (by Zamp), I was told that the Zamp feet are not as big as the AM solar feet and they do not recommend the VHB method for that reason.
The Zamp team are great, call them and they will happily give you their first hand opinion.
Always best to get it straight from the horses mouth!
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-14-2020, 12:40 PM   #4
2021 16' Caravel
Thanks!
did you use these?
https://www.amazon.com/dp/B00BR3KFKE..._FSFdFbZQBR0QN
These brackets looks good, 1x4 contact area should be good. do you find it difficult to tighten the screws from underside, especially for the 2 towards the center of the roof?
-Hovr
Old 07-14-2020, 02:46 PM   #5
1972 23' Safari
Thanks!
did you use these?
-Hovr
I got those and also the ones for curved roofs. The flat brackets I used on top and the curved ones towards the bottom.
https://www.amazon.com/Renogy-Solar-...57239297&psc=1
As for tightening the top bolts you just need small wrenches which helped a lot with the install. Also placing the top brackets closest to the solar panel corners. Tighten the top bolts first before doing the bottom ones.
Old 07-15-2020, 05:33 PM   #6
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
My 32 bonded AM mounts are still there after 5 seasons. I would recommend you clean the mounting area with carburetor cleaner. No need to scrape away the paint.
guskmg
Old 07-15-2020, 06:08 PM   #7
dznf0g's Avatar
Oswego , Illinois
I wouldn't remove the paint either. I used several applications of a quality cleaner/wax to remove all oxidation and impurities. Then several rub downs with prep solvent to remove all wax. Likewise, it has been about 5 years with no lost adhesion.
-Rich-
Old 07-15-2020, 09:51 PM   #8
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
AM brackets are the gold standard. 32 feet with VHB/silkaflex and 3 seasons later no problemo.......
ID:	373029   Click image for larger version
ID:	373031   Click image for larger version
wulfraat is offline   Reply With Quote
Old 07-16-2020, 01:17 AM   #9
2021 16' Caravel
$80/set pricing is pretty hard to swallow . For your setup it's $80x8 = $640 :O
Removing solar panels mounted with VHB cerickson Generators & Solar Power 13 03-05-2018 09:21 PM
Which VHB Tape for Mounting Solar Panels pteck Generators & Solar Power 1 08-31-2017 12:15 PM
Using VHB Tape on International Interior Wall CAK General Interior Topics 13 08-14-2017 12:58 PM
Odd response from 3M about VHB 4950 tape woundedpig Electrical - Systems, Generators, Batteries & Solar 10 06-30-2017 09:14 PM
VHB installation in winter Troutboy Boondocking 2 01-07-2017 07:22 PM
