Old 08-28-2017, 09:42 AM   #1
2018 19' Flying Cloud
Eugene , Oregon
Using Two Portable Solar Suitcase Panels
I currently have a 100w Renology solar suitcase panel that I connect to my (parallel) batteries via Anderson Pole connectors / panel mount. As you can see from the graphic, a second set of inputs is available. A friend is lending me his 100w Renology suitcase, so I would have two! Would there be any disadvantage to connecting / running both panels at the same time - each with their own independent controller plugged into the panel to have 200w?
Name:	powerwerx-panelpole-panel-mount-housing-for-two-powerpole-connectors-with-a-weather-resistant-co.jpg
tjwoods1 is offline   Reply With Quote
Old 08-29-2017, 08:58 AM   #2
2015 30' Classic
Pleasanton , California
Connecting two suitcase panels and controllers to your batteries simultaneously is fine to do with no ill effects.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Best 200 W portable suitcase solar setup ??? Milo1952 Electrical - Systems, Generators, Batteries & Solar 17 08-21-2018 09:38 PM
Portable Solar Panels Fancypantsas Batteries, Univolts, Converters & Inverters 8 08-09-2016 10:43 AM
Solar panels vs portable generators ashe Electrical - Systems, Generators, Batteries & Solar 19 01-19-2015 07:18 AM
Portable Solar Panels migriffin Sprinter and B-van Forum 31 04-11-2014 06:56 AM
