Old 10-15-2017, 05:59 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
two different batt types- Possible simultaneous usage?
i have the Lead acid batt that came with the 22FB
over the winter i want to get a lithium battery
my current PD converter does NOT support lithium.
i might replace it or get a new converter that supports lithium
if i do the later. can i use both batteries at the same time?
ie the old converter charges the lead acid
the new converter charges the lithium.
if i do that, can the two battery both drive the 12 V system or or do all batteries need to b of the same type?
if i can use the different types, how do i do that?
waninae39 is offline   Reply With Quote
Old 10-15-2017, 06:16 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Simple answer no.
More detailed answer:
Lithiums and lead acid's are very different batteries. You have to keep them completely isolated from each other. You can not charge them from the same charger (run them in parallel). If you try to power a load off of both of them, only one battery type will supply the entire load current.
This even extends to chargers. A charger that "can do both" likely does both poorly. The firmware in the charger needs to be aligned with the battery type. Most chargers have a really hard time with this. They either do one or the other well and the alternate poorly.
blowout plug: two types? Atsushi Winterizing, Storage, Carports & Covers 0 10-02-2017 07:45 AM
Two types of aluminum on the outside? Jhiner1978 Cleaning, Stripping & Polishing 5 05-07-2017 12:09 PM
Simultaneous portable solar and generator whitegs Generators & Solar Power 12 08-24-2016 08:13 PM
Tires - two different types on the same trailer A W Warn Tires 11 03-07-2015 12:29 PM
Stripping A Painted 31 Intl. Different types of AL? redthies Cleaning, Stripping & Polishing 1 06-20-2010 10:48 AM
