Old 12-06-2022, 11:52 AM   #1
Plainfield , Indiana
truck to trailer charging with new Renogy DC to DC MPPT charger
I was wondering do I just run to 6AWG from my Tundra batt back to the trailer? Do I just fashion some type of plugs that let me plug and unplug when I unhitch? Any suggestions?
rfequity1 is offline   Reply With Quote
Old 12-06-2022, 11:59 AM   #2
2023 28' International
Mercer County , New Jersey
Most run a thicker wire than 6 gauge and usually use welding cable.
As far as connectors, Anderson is the way to go.
jeffb831 is offline   Reply With Quote
Old 12-06-2022, 12:23 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I ran 6 ga from the truck battery to the rear bumper. At the rear bumper I installed one half of an Anderson connector. They are the go-to connector for this type of thing, but make sure you get the proper size for the wire & amperage involved.
On the trailer I ran 6 ga from the DC-to-DC charger to the tongue. It is bundled along with the 7-wire cable and gets plugged in right next to it.
6 ga wire is good to about 50 amps, so unless you're planning to pull that much from your truck battery you should be good to go. Most DC-to-DC chargers are much less than 50 amps on the TV side, but do the math and double check.
Running the wire through the truck was pretty simple for me. I just found a factory run that was clipped inside a frame rail and zip tied to that along the way. At the front I installed an appropriately sized weather proof DC breaker before the connection the battery in the even the cable shorts out somewhere.
Richard
11018
richard5933 is offline   Reply With Quote
Old 12-06-2022, 12:26 PM   #4
2022 25' Globetrotter
Madison , Alabama
Which Renogy DC-DC charger are you installing? 6 AWG may be OK for a 20 amp model, but suggest bigger for anything else.
As jeffb831 mentioned, Anderson Power Pole connectors in the appropriate size are the way to go.
Here's a pretty slick install showing use of the Anderson connectors:
https://www.adventurousway.com/blog/...uck-12v-socket
Tyler2you is offline   Reply With Quote
Old 12-07-2022, 12:39 PM   #5
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
That what I did. Used 4 gauge welding wire with a fused blue sea solenoid. One of our Ford up fitter switches controls power from the truck battery back to the Anderson connector to the Renogy. Ground was from the Anderson connector to the rear Ford frame factory ground.
Life is a Highway is offline   Reply With Quote
Old 12-08-2022, 02:35 AM   #6
2021 27' Globetrotter
Tallahassee , FL
We are using the Renogy 20amp DC2DC charger with our 21GT27FBQ and GMC 2500HD. I ran 4 gauge weld cable from battery to a 40 amp breaker in the engine compartment. 4 gauge to the rear followed frame rails. At the hitch used an Anderson 4 gauge connector
So I can plug in if and when needed. From the Anderson ran 4gauge to the Renogy which is mounted in the front compartment and then to the lithium batteries also mounted in the front compartment.
Kawboy01 is offline   Reply With Quote
Old 12-08-2022, 04:23 AM   #7
1994 25' Excella
Curious why you ran 4ga for a 20amp charger? Even at it's max 6ga would have been enough. Was there some reason?
Richard
11018
Old 12-08-2022, 04:41 AM   #8
TeddyK's Avatar
Boston , Ma
Following
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
TeddyK is offline   Reply With Quote
Old 12-09-2022, 02:02 AM   #9
Tallahassee , FL
We could have used a smaller gauge but I used 4 gauge for the rest of the lithium upgrade and had all the connectors and cable to do the job. Never gonna need to upgrade this if we ever went with more amps but after over a year this is plenty of "juice" for our purposes.
Old 12-18-2022, 10:37 AM   #10
Racine , Wisconsin
Great article. Thanks.
I’ve been pondering the same question. I have been using an old 1000 W Honda generator to run a 40 amp AC battery charger to charge batteries on my trailer. I’ve been thinking I should be able to add a 1000 W inverter to the truck and then just run AC back to battery charger on the trailer. I’ve never seen anyone else bring this up and wonder if there’s some caveat to doing so?
Dave Bybee
2017 Ram diesel, air suspension
1986 Avion
Kilroy is offline   Reply With Quote
Old 12-18-2022, 12:07 PM   #11
Highlands Ranch , Colorado
A 20 amp DC-DC charger outputs 20 amps. The input side could go as high as 30 amps, but I would expect around 25 amps.
Using the worst case of 30 amps, with a 60' round trip from the battery to the DC-DC charger on a 12 volt system (using 12.00 volts), 4 awg has a 3.84% voltage drop. The 6 gauge would be 6.10%. We're usually limiting voltage drop to no more than 3%.
Is it as bad as that? Probably not, but if the trailer batteries are at a low state of charge you could be pulling a lot of amps for an extended period of time from the truck battery/alternator.
There should also be an appropriately sized fuse at the truck battery where the cable to the DC-DC charger connects.
Wire Gauge Calculator:
https://baymarinesupply.com/calculator
2006 Fleetwood Gearbox 220FB (toy hauler) <- current
2017 F-350 CCLB 6.7L
2019 Nissan Leaf SV+
HRTKD is offline   Reply With Quote
Old 12-18-2022, 08:51 PM   #12
1988 32' Excella
Robbinsville , New Jersey
It's been done, there is a thread about it somewhere. The person that did said it was working well at the time. The main concern for many was the environment the inverter was in under the hood and how it would effect longevity.
Old 12-19-2022, 07:01 AM   #13
rich.dev's Avatar
2016 26' Flying Cloud
Guelph , Ontario
Very good point, here is a nice YouTube video from Nate (from Explorist life) explaining it.
https://youtu.be/0xOvINH4tKs
rich.dev is offline   Reply With Quote
Lithium DC-DC Charger Help Needed! Renogy 100AH heitz1978 Batteries, Univolts, Converters & Inverters 13 08-19-2022 07:33 PM
Suitability of the Renogy 12V Inverter Charger w/ Display for my '66 Renovation kgracey Batteries, Univolts, Converters & Inverters 1 04-20-2022 10:01 AM
Renogy solar install, options for non Renogy monitoring bmklawt Generators & Solar Power 9 03-05-2022 08:47 AM
Renogy Suitcase and converter/charger setup zlarryb Generators & Solar Power 8 07-05-2020 11:14 AM
New MPPT Solar Controller c21 Sprinter and B-van Forum 4 10-09-2017 07:07 AM
