Old 10-20-2021, 07:43 AM   #1
2017 27' Flying Cloud
Celina , TX
Truck Bed Power Outlet
Weíre occasional boondockers looking for the lowest cost alternative for keeping the trailer batteries charged. Not looking to run air conditioners or even a coffee maker. Iím looking at portable generators and portable solar, but what about the 400W truck bed outlet as an option?
Is this a viable option for battery charging? Any advice is appreciated.
Texasbr549 is offline   Reply With Quote
Old 10-20-2021, 07:59 AM   #2
Rich W's Avatar
I'm In , Kentucky
400 watts is 3.3 amps, not much of a charger and it would be draining your truck battery. I can run my laptop off of 300 watts. You can probably charge faster through your umbilical cord. Instead of having it as a truck bed option you can buy a HFT inverter and connect it to your batteries and see if that works for you. It would be cheaper
I think a small generator would be better.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 10-20-2021, 04:39 PM   #3
Chelsea , Maine
You’ll drain your truck battery and need a boost to get started again. Depending on the remoteness of your boondocking site, that could be a big problem.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 10-21-2021, 06:46 AM   #4
Celina , TX
I would only try charging the batteries with the truck running so the question is whether the batteries would charge given the low amperage. The trailer is connected to 5 amp outlet at the storage space when not in use, but thatís maintaining a charge after a trip instead of trying to recharge in a remote area.
Old 10-21-2021, 07:29 AM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
In order to calculate if it will work, you need to know the electrical draw amperage from the converter in your trailer?
IMO, even if it will work, you would be better off with a small generator. Your truck idling for 2 or 3 hours to charge your battery is more costly in the long run (wear & tear on the engine, alternater, etc and more fuel)
Alan
Power sofa, power bed, etc. Billstream Airstream Trailer Forums 4 03-04-2016 08:07 PM
GFCI Shore Power Outlet Trips JRF0st3r Electrical - Systems, Generators, Batteries & Solar 12 06-20-2012 12:24 PM
Power outlet problem, help! mico75 Batteries, Univolts, Converters & Inverters 5 07-31-2009 08:29 PM
Microwave 110v power outlet location? SnoSheriff Stoves, Ovens & Microwaves 1 07-24-2009 01:46 PM
Need to find adaptor to go from this outlet on my generator to shore power line in AS wacnstac Generators & Solar Power 11 04-27-2006 12:49 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
