Old 07-14-2018, 08:11 PM   #1
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Touringdan’s simple portable 200 watt solar system
We generally camp without hookups but have two golf cart batteries (220 amp-hours capacity total) and are frugal with our use of power. We also usually only camp for a few days, so our batteries have been fine and we didn’t feel a need for solar. However, we have planned to start camping for longer periods so have been giving solar some thought.
A while back I looked at a thread showing Grape 100 watt panels available from HD for $100 each with free shipping. I also read that solar panel prices may going up due to politics. So I went ahead and ordered two 100 watt Grape solar panels. I got a call from HD a few days later and picked them up. It was that easy.
I have read some threads about installing solar panels on the roof. This usually seemed to be on newer Airstream’s and the cost seemed very high partly I suppose since it always seemed to be incredibly complicated. Being complicated and high cost is not for me. I decided on a portable system. Plus I want the Airstream in the shade and the panels in the sun.
I looked at AirMiles thread and he had an MPPT solar controller from Victron which he liked and could send the information to your phone via Bluetooth so I ordered the MPPT 75/15 Bluetooth solar controller from Amazon for $125. I needed some other stuff like panel adjustable supports, 60 ft of #10 wire, mp-4 connectors and a tool to install the connectors onto the wire. This stuff was about $150. So my material cost was about $500 for my 200 watt portable system. I probably could have purchased two 100 watt suitcases or a 200 watt suitcase system for not much more but I wanted the flexibility of selecting the mppt controller and the length of the cable. Installation of the mppt controller was pretty simple as my two golf cart batteries are in the rear. I made a bracket for the solar controller and wired the connections to the battery with a 30 amp fuse and the connections for the solar wires just below the belly pan (see photos).
I carry the two panels standing up in the covered bed of my Tundra and they ride fine there. On two of our last three trips we were camped in full shade, so didn’t even try solar. The other location had some sun so we used the solar panels and they worked fine. I am a solar newbie and don’t really understand the information yet, but I got 900 watt hours of solar energy from my 200 watt panels on a sunny day and that seems pretty good.
Having solar will give us much more ability to use more power for uses that we were didn’t even think about before. Examples are more fan use to combat hot weather or bugs, our new 350 watt rice cooker, our 65 qt Dometic compressor fridge in the Tundra, recharging my blower, etc.
DanClick image for larger version
ID:	316932Click image for larger version
ID:	316933Click image for larger version
ID:	316934Click image for larger version
ID:	316936Click image for larger version
Old 07-15-2018, 09:38 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I would just like to add that another reason to go with solar is the flexibility it provides especially when you go to a place like Yellowstone NP. The large campgrounds in Yellowstone have electric and water and take reservations, but the smaller campgrounds are all first come, first served and don’t have electric or water hookups and don’t allow generators.
Dan
Old 07-16-2018, 08:06 AM   #3
2008 27' Safari FB SE
Miami , Florida
For the record: only the Fishing Bridge RV Park in Yellowstone has hookups. All of the other campgrounds are dry camping.
Fishing Bridge RV Park is scheduled to be closed for the entire 2019 season.
Middle-aged (usually dirty) Nissan Titan XD
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Goofy dog
Old 07-16-2018, 12:30 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Touringdan’s simple portable 200watt solar system
Thanks for the correction David. It looks like the larger campgrounds with reservable sites allow generators while the smaller campgrounds that are first come, do not allow generators.
Dan
Old 07-17-2018, 04:05 AM   #5
"Hey, I know you!"
Boog's Avatar
Chapin , South Carolina
Looks good Dan, I got the $100 Grape solar panel deal from Homer Depo too. I’ve been playing around with portable solar recently because I have more than one camper and want to use the solar setup on any one of them. I’ve watched a bunch of YouTube videos about portable solar generators but decided to make something without a battery. My box has a cheap pwm controller, 12-volt cig and usb plugs, cheapo battery monitor, a solar input and fused leads so I can charge any battery and power 12-volt accessories with it. The box weighs less than 2 pounds and it cost about $75. Once I use it some and work out any kinks, I’ll probably make another one and use better components like the stuff you used (and I’ll be consistent with my wiring colors). If you have the room to carry it and don’t mind the setup, I think that portable solar is the way to go… park in the shade and put your panels in the sun.
ID:	317210   Click image for larger version
Boog is offline   Reply With Quote
Old 08-15-2018, 02:23 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I just wanted to show a photo of how I carry my two 100 watt panels in the back of my Tundra. Presently I am carrying only two panels because that is all I need. I could carry two more panels and have the capacity, in my wiring and solar controller, for 400 watts if I needed them. If I went this route I would wire two panels in series and then two in parallel.
I also included a photo that shows my extra Dometic compressor operated refrigerator that operates on 12 volts. Having the solar charging capability allows the luxury of having this extra refrigerator. It draws about 50 watts and probably runs about half of the time.
ID:	319952Click image for larger version
Old 08-15-2018, 03:02 PM   #7
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Nice setup TouringDan. Looks like your solar system is producing watts as I would expect. But your batteries are being drained too far into the low-11 Volt range daily. My pair of 6V golf cart batteries usually only drain down to 12.2V even with heavy usage. Either your batteries are bad or you are using more Amps daily than they can hold. Your Victron controller should “float” your batteries each sunny day and the batteries should get to 14.4V to 14.6V each day while charging. See my “Solar Show & Tell” thread to see how my system performs. http://www.airforums.com/forums/f448...ml#post2133206
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 08-15-2018, 03:29 PM   #8
"Cloudsplitter"
We...
...Kiss too... only in the USA if possible. 😂👍
Try to stay away from HF.
ID:	319954   Click image for larger version
ID:	319956   Click image for larger version
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Old 11-26-2018, 07:28 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
DanAttachment 319952Attachment 319953
I just want to point out an error in the above paragraph that was pointed out to me. My solar controller is adequate for 200 watts of solar, but not for 400 watts. For 400 watts of solar I would need to install the Victron SmartSolar MPPT100/30 controller.
Dan
Old 01-03-2019, 09:54 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I have just finished installing a new “power plant” in our 66 Tradewind (photos 1&2). The power plant consists of two 100 Ah Battleborn lithium batteries and a 2,000 watt Samlex pure sine inverter. The inverter has a remote switch (photo 3) that we can turn on inside the Airstream and all the receptacles are energized. When the Airstream is at home we no longer use shore power to keep the batteries charged up but use our simple 200 watt portable solar system (photo 4).
Dan
ID:	331018Click image for larger version
ID:	331019Click image for larger version
ID:	331020Click image for larger version
Best 200 W portable suitcase solar setup ??? Milo1952 Electrical - Systems, Generators, Batteries & Solar 17 08-21-2018 09:38 PM
Zamp solar 200 watt portable solar charging kit Cascadian Airstream Classifieds 0 05-11-2018 08:13 PM
200 Watt Solar Install on 2016 Flying Cloud 19' Snowy Generators & Solar Power 6 11-26-2017 04:44 PM
130-watt Portable Solar louaxtjr Airstream Classifieds 0 09-22-2013 05:32 PM
130 watt portable solar louaxtjr Generators & Solar Power 2 05-21-2013 06:04 PM
