Old 07-03-2020, 09:13 AM   #1
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
This seem like good value?
And,, Most important a good usable solar suitcase? I’m just looking to keep regular 12volt Interstate batteries charged. We will NOT be running AC, microwave, but we may have to run the propane furnace a bit in the morning. (25’ Globetrotter.)
Also,, Do I need 200w? Is there an advantage (speed to recharge) to going with 200w vs 100w?
I don’t want it stolen. So I can lock it up when we are not around. I’m adding the long cord because we always prefer shaded spots. Hopefully I can get the solar panel into the sun. We will also have a Honda 2000 with us. (Have EasyStart).
Jeff
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 07-03-2020, 09:34 AM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Following!
Old 07-03-2020, 09:45 AM   #3
2017 30' International
Box Elder , South Dakota
It’s a great kit. I have one. If you have the Zamp port on the battery box you will likely need to swap the positive and negative wires on the voyager controller.
Not sure where you are located...but since our current trailer came with roof solar, I’m looking to sell mine. (Happy to edit/delete this if that’s not allowed)
Labeda14 is offline   Reply With Quote
Old 07-03-2020, 10:22 AM   #4
GettinAway's Avatar
Wildwood , Missouri
Hey Labeda14. I’m in St Louis Missouri area, but heading to WY next week. Would be happy to detour up to SD. I’ll send you a PM.
I had heard about the swapping of the leads.
2020 25GT FBT
Old 07-03-2020, 10:40 AM   #5
Prosper , Texas
Howdy - new guy here - if my Airstream does not have solar (but was pre wired) ... how would I connect / use a kit like this one?
Thank you
2021 Intl 27FB on order
Octane1 is offline   Reply With Quote
Old 07-03-2020, 11:29 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our older Classic does not have the factory Zamp connector, so I charge thru the 7-pin directly to the batteries. With two 160w Zamp Suitcase panels👍
POI...the 7pin connector has had the polarity reversed to match the Zamp wiring.
ID:	371844   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
Old 07-03-2020, 11:53 AM   #7
GettinAway's Avatar
Wildwood , Missouri
Thank you
Octane1,
I believe your trailer will have a solar connection on the A frame of the tongue. I think all never AS trailers have this connection. But for the system shown above the wiring is backwards and the Wiring on the panels you plug into the trailer need to be reversed. Not all systems need reversed though.
2020 25GT FBT
Old 07-03-2020, 03:14 PM   #8
Prosper , Texas
Thank you. I have a lot to learn. This forum, the members and the mountain of data is great for us new folks.
Old 07-03-2020, 10:18 PM   #9
Boondocker in Training
2020 27' Globetrotter
Los Angeles , California
I've never met anyone who wished they bought fewer panels.
The 100 or 200 question is difficult because I don't know how much you can generate in your area. This depends on how far north you are on, the season, how much south/west facing sun you can capture...
If you can't make 100, having 200 won't be helpful.
If you can make over 100, you would wish you had 200 because it's going to waste.
Speed of charge with 100 or 200 is, IMO, the wrong metric. It's "how much" because you can't control the sun. More panels. More power generation. More powering coming in? More power, faster but not "faster power."
Camping David
Shelter: 2021 - 27 Globetrotter FB Twin (on order)
Tow Mule: 2020 - Ram 1500 Classic "Warlock"
CampingDavid is offline   Reply With Quote
Old 07-04-2020, 05:43 AM   #10
GettinAway's Avatar
Wildwood , Missouri
Got it. Thanks! Amazon had a used one for $300. Still in original packing. (200 watts)
So we are taking it with us to WY after I change the positive and negative wires..
2020 25GT FBT
Old 07-04-2020, 11:35 AM   #11
solomon.m's Avatar
2020 27' Flying Cloud
Foster City , California
Can someone draw or explain the "reversing the wires" described above? I have a 2020 FC and bought a 45W Zamp panel to be a battery tender in my storage facility. I simply plugged it into the Zamp port on the hitch and now see a positive value (current going into) my batteries on the BMV 712. Appreciate insights from the collective wisdom here. Best, Michael
solomon.m is offline   Reply With Quote
Old 07-04-2020, 01:16 PM   #12
2019 25' Flying Cloud
Gainesville , Florida
Following re: reversing the wires.
Is this only necessary if using the umbilical cord for charging via portables or is it also necessary if going from the portables to the Zamp port on the hitch?
(Sorry for the simple question but totally ignorant about solar.)
djbar is offline   Reply With Quote
Old 07-05-2020, 06:01 AM   #13
GettinAway's Avatar
Wildwood , Missouri
I hope one of the solar experts jumps in here. I’m not sure of the answers.
2020 25GT FBT
Old 07-05-2020, 06:22 AM   #14
Zamp wires their plugs backwards (positive connected to the negative lead) so when you plug in to the Renogy solar controller it showed an error. When I called them and gave them the error code, he explained that the positive and negative leads were reversed. So the easiest thing to do at that point was swap the wires that go into the controller (just two screws). So if you are using zamp panels you won’t have to do anything. But if you want to use the zamp plug in the battery box with a different panel/controller manufacturer, you likely will have to swap the leads
Old 07-06-2020, 05:22 AM   #15
GettinAway's Avatar
Wildwood , Missouri
Labeda,
I was thinking I would switch the wiring on the panels, but you just swapped the wires in the connector on the frame of the trailer? Sounds like the better (cleaner) way to go. Just pull that plug receptacle swap the wires going into it, and re-install, correct?
Thx
2020 25GT FBT
Old 07-06-2020, 05:26 AM   #16
I switched the wires on the controller that is attached to the panels. I did not change anything on the trailer
Old 07-06-2020, 05:30 AM   #17
GettinAway's Avatar
Wildwood , Missouri
Got it. Glad I asked.
Thx
2020 25GT FBT
Old 07-06-2020, 05:38 AM   #18
You can use one of these in the charge line.
I charge thru the 7-pin umbilical so I just reversed the wiring there.
ID:	372061   Click image for larger version
Molly Ivins
RLC
Tahawus
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 01:37 PM
Why does my electrical seem like its surging dmcinfo Lights - Interior & Exterior 1 07-08-2010 10:48 PM
It's Getting Embarrassing,....I Can't seem to Win the Lottery ! MileHigh Our Community 2 05-09-2004 07:29 PM
Can't seem to get H2O from faucets dinoburb Fresh Water Systems 11 08-11-2003 06:56 PM
