02-21-2020, 07:00 PM
#921
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Originally Posted by pcskier
Or just use the side cutters as a fuse.
Nice work Ronnie. Tight and organized. Yet again my electrical area is a disgrace by comparison. Everything works, but still...
Maybe use the wire cutters to cut the wire then the fuse would slide off the wire and the zip tie is a nonissue....
02-21-2020, 09:03 PM
#922
2007 22' International CCD
Corona
Solar Show and Tell
The use of plastic covered bread ties are a nice way to recycle them, temporarily tie wires in bundles, and would be very useful for spare fuses as well.
Bread ties now seem to be the wire coat hangers nowadays. They seem to be everywhere and when you stash them in a drawer, they rapidly reproduce in the darkness therein.
I also use zip lock plastic bags and a bit of duct tape to stash spare parts like fuses and screws next to the point of possible need. I’ve been known to use a bread tie and a ziplock bag with a small hole punched in it to accommodate the use of a bread tie.
02-22-2020, 02:25 AM
#923
Kiwis on the move
2018 27' Flying Cloud
Auckland
, New Zealand
Originally Posted by Wolfwhistle
DC breakers could serve as switches... not constant use, but works for what we might need. I would go with 30 amp between combiner and MPPT, and then 40 amp (seems like its enough) between MPPT to a bus rather than the load center (DC side) using Midnight solar mini breakers on a DIN rail. Also why increase wire gauge PV to MPPT from 10 to 6 awg? Of course, I don't know the length of the run. Surprised that you can fit 160s on a 27 footer. Link to mini breaker housing. Breakers are easy to find. https://www.googleadservices.com/pag...gQIDRBC&adurl=
WW
Thanks for looking at the drawing.
I think I will stay with the switch.
There is a possibility If everything was right on a good day, I could get over 40amps out of the mppt so thats why I went for the 60.
The wire size at 6 was just because I had it I could use 10
Will post photos of panels if I can get them to fit. If I can't will have to look at a 30ft
Chev 350 dually 2005
Solar 320W More to come
Equalizer hitch
02-22-2020, 02:09 PM
#924
2001 30' Excella
Full-time traveling
, Hmmmm. what day of the week is it?
Here is our solar setup
02-22-2020, 02:35 PM
#925
Overkill Specialist
Dadeville
, Alabama
Originally Posted by JBBeaubeaux
Looks great! Vinnie does a super job. He is a class act.
02-22-2020, 04:52 PM
#926
Overkill Specialist
Dadeville
, Alabama
Here is a a NERD post. New crimp tool does a great job. Check out this cold weld. The ends are acid etched so you can see better.
02-22-2020, 05:59 PM
#927
2017 23' Flying Cloud
Parker
Cool Ronnie, what tool is that?
Troutboy
02-22-2020, 06:07 PM
#928
Overkill Specialist
Dadeville
, Alabama
Burndy MRC840 UL listed $$$ but works great.
02-22-2020, 07:39 PM
#929
2004 28' Classic
Monument
When I did my original electrical system rebuild, Lewster was my main advisor. He convinced me that good crimps were one of the keys to a quality system. I bought a good crimping tool from Germany, Greenlee, and have never regretted the investment.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
02-22-2020, 07:45 PM
#930
Overkill Specialist
Dadeville
, Alabama
Very nice!
02-23-2020, 01:30 AM
#931
Kiwis on the move
Auckland
, New Zealand
Thats impressive
I had no idea that you could compress the wire that tight
Equalizer hitch
02-23-2020, 05:35 AM
#932
2018 27' Globetrotter
Apollo Beach
I bought the Harbor Freight Hydraulic Wire Crimping Tool: https://www.harborfreight.com/hydrau...ool-66150.html
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
02-23-2020, 06:46 AM
#933
Overkill Specialist
Dadeville
, Alabama
Originally Posted by KiwiNZ
Thats impressive
I’d never cut one open because the dang crimps cost so much, but I messed up the other day and needed to shorten my battery jumpers so I had a few very short ends with crimps on them.
I’d seen it done on YouTube before so I thought I’d give it a go.
I carefully cut across the center of one of the crimps being careful not to get the cut to hot. Then I cleaned up the end with a file one going in one direction. Then I acid etched the end to remove any copper filings that might have gotten “smeared” into the joint and to “stain” the joint to help identify any gaps. Note that the acid etch actually ate off some of the tin coating the lug had on it.
Pretty cool test of ones tools ability.
I just bought this Burndy tool and I like it because when you cycle it you cannot under or over crimp a lug. ( provided you use the correct die).
It also stamps/embosses each lug letting you know you did it right.
02-23-2020, 06:48 AM
#934
Overkill Specialist
Dadeville
, Alabama
Originally Posted by AirMiles
I have this crimp tool also and it works great for smaller stuff like 6ga-2ga.
Mine will not crimp anything larger than 0awg.
02-23-2020, 02:33 PM
#935
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
I'm not going to even mention my $20 hammer crimp tool. Embarrassing.
02-24-2020, 01:51 AM
#936
Kiwis on the move
Auckland
, New Zealand
How does it it work? Well I Know how it works but how have you found it?
Are you keen to cut a crimp in half to see the difference, it would be interesting
Equalizer hitch
02-24-2020, 08:01 AM
#937
Wolfwhistle
Margaritaville
, Banana Republic
I use a 16 ton (so called) Chinese, bought off Amazon. I did cut into a crimp from a #4/0 copper - not annealed or zinc type... I also use an anti corrosion paste - it looks almost like solid copper not a hint of any gaps. I kinda think one could crimp with too much force; although, I squeeze pretty darn tight. Now this cheap crimper is just that and the dies are in metric. So, I use the one that seems to be right. It goes down to around a 4 awg cable and up to something larger than #4/0. If I knew how many cables / crimps I would eventually make, the professional model would have been the way to go.
Edit: I meant to add, a ratcheting PVC cutter cleanly cuts up to #4/0 cables.
WW
Is taking it all with you, really getting away from it all?
02-24-2020, 11:46 AM
#938
Parker
I used an anchor, similar to the greenlee and the burndy....
https://www.ancorproducts.com/en/703040
Troutboy
02-24-2020, 12:07 PM
#939
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
And a pair of side cutters to cut the zip ties, so you don't try it with a knife and cut yourself to the bone.
WW
Hi
Wish you had brought that up about 4 years ago before I got these stitches in my left hand .....
03-02-2020, 07:26 AM
#940
Springtown
Flush cut pliers are really too cheap to not have in the tool box. SPEEDWOX Side Cutters 6 Inches Flush Cutters
Alternatively I have taken spare side cutter pliers to the grinding wheel and converted them to flush cut pliers for zip ties.
I have used some really crappy pliers this way and they all cut zip ties great even though in their previous form they could barely cut bailing wire. The flush cut conversion makes them very sharp. You will wonder what took you so long to make a set. This is my current set from some old pliers in my tool box that had broken tips.
2014 Torque TQ290, Hensley Arrow w/adjustable stinger
2022 F-350 Platinum DRW, 4x4, 6.7, 3.55
2008 KTM 300 XC-W
2010 Kawasaki KX250F
2018 Can-Am Maverick Trail 800 DPS
