Old 08-05-2018, 01:04 PM   #21
2003 22' International CCD
East Durham , New York
Solar
Excellent, I have the fuse holder ready. I guess it doesn't matter which post, right? they each have a number written on them.
Thanks again for your help.
James
bluvalley is offline   Reply With Quote
Old 08-05-2018, 02:02 PM   #22
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Not to copper side. See pic. If you hooked to the copper side it would have to back feed through the 30 amp auto reset fuse under the bar. You need to hook it to the incoming wire side NOT the post fuse side.
Old 08-05-2018, 02:10 PM   #23
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
More detailed pic
Old 08-05-2018, 04:22 PM   #24
Solar
Thank you!!!!
Being electrically challenged I really needed those arrows! Much appreciated!
Wish Airstream had instructions like that.
Old 08-05-2018, 05:42 PM   #25
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
The Airstream wiring schematic shows the positive output wire from the controller going to the copper side of the connection in my owners manual. Yes, it travels through the fuse back to the battery when wired that way. That is how I wired mine and how I’ve seen factory solar systems wired. It will “work” connected either way. You can see this in the schematic posted here: http://www.airforums.com/forums/f448...ml#post2138031
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 08-05-2018, 07:01 PM   #26
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
That is not correct. Here is a flow diagram.
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 03:28 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 07:11 PM
