Old 09-28-2021, 04:56 PM   #1
2016 22' Sport
MIDDLETOWN , RI
Solar power to "trickle charge" stored trailer battery
I mostly use my trailer off grid in TX for a couple months in Texas in winter. I am going to add one BattleBorn battery and pick up a single propane power Honda EU2200 but would like to put a small solar panel in a south facing window when the trailer is stored to keep the battery charged.
Anyone else doing this?
GaryRI is offline   Reply With Quote
Old 09-28-2021, 06:37 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The problem is the size of the solar panel. The typical "fit it in the window" panel does not deliver a lot of power. Toss in the non-optimum mounting location and things get worse.
The simple answer is to put in a full disconnect switch. You should easily be able to store the BB batteries for a couple of years , just using that. I've done that om my trailer. It's worked fine.
Old 09-28-2021, 06:59 PM   #3
2007 16' International CCD
Somewhere , Colorado
.The simple answer is to put in a full disconnect switch. You should easily be able to store the BB batteries for a couple of years , just using that. I've done that om my trailer. It's worked fine.
X2
An iffy proposition with lead acid batteries, but with the very low self discharge rate of lithium batteries this is the answer. Have the shop do it while changing the battery cheap and easy.
field & stream is offline   Reply With Quote
Old 09-29-2021, 10:02 AM   #4
2016 22' Sport
MIDDLETOWN , RI
re: disconnect switch
Hi
So just remove the battery terminals?
Old 09-30-2021, 07:17 AM   #5
Half a Rivet Short
2022 Interstate 24X
Hi
Yup, just pull the wires off the negative side of the battery. Loosen the bolts and slide them off the posts if you have that sort of attachment. Pull the bolts if you have tabs with holes in them ( Best bet is you have posts, just like on a car battery on your lead acid batteries now. You will have the tabs with holes on the BB lithiums ).
Solar trickle charge bbruntil Generators & Solar Power 2 11-14-2018 11:55 PM
Solar trickle Charge philipsinewe Batteries, Univolts, Converters & Inverters 8 11-03-2016 11:23 AM
Solar trickle charge mike28 Generators & Solar Power 11 04-18-2014 08:56 PM
Will mini solar panel trickle charge over winter? woodytwo Land Yacht/Legacy Motorhomes 14 12-19-2011 05:24 AM
"lived in" vs "stored" ?? tomcook Buyer Guidelines 5 03-16-2006 09:23 AM
