Ahhhh those Solar Panels. Mounted on top of most Travel Trailers WITH... Solar. No such things as Solar Batteries. Do you also play poker? Quit dreaming, the panels are either there or not there. Tree limbs can modify your trailer's AC and Solar options. Do you have trees along your driveway. Something hanging on some? Check it out. OK, now get serious.
The Aluminum Roof painted white on some, does nothing, as you may think. It is either hot or cold. That is it. Also slippery when wet. Get with it.
Cannot SEE the panels standing next to the trailer? They might still be there. Otherwise, that explains why they have not worked for several years. If this is difficult, go to another thread about Tire Pressure. I am cured of PSI...
Cannot easily CLEAN them, as well. But get a good night's sleep and do it anyways.
January 1st... A Good Day to Die... trying to meet one goal this year. I have no life insurance. Much like a uncharged battery, my days are numbered. Every morning I awake is a Good Day.
The Solar Panel is an energy producer... when the Sun is out. Much like breakfast this AM. I was charged and 'whipping the glass' cleaner mood. Grrrrr...
- Ladder, tall enough and stable. Mine meets this fairly well. Most ladders have a weight limit. Do you qualify? You may need a Fork Lift.
- Glass Cleaner: From Costco- Sprayway Glass Cleaner: NO Ammonia, Streak Free. Clean, Fresh Scent too. Not for Flat Screen Televisions... it says. OK? No mention of Oliver or Airstream Trailers with Solar.
I wipe with USED micro fiber on the first wipe. Do not need much, but just enough of the Costco whatever is in the can.
I finish, if needed, using a new or less used micro fiber, from Costco by the large package (of course), and catch anything I missed.
Getting UP and DOWN a folded ladder is important. Many casual home ladder climbers die each year cleaning Windows. Not Solar Panels... so this must be a safer use.
If you believe your Solar Panels are a bit... unproductive... climb up a ladder and look. After a light shower... I promise you the dirt is part of the process of burying your panels under mud, turned to dirt attached to your Panel or Panels.
They have been stolen at the RV Storage Park the trailer is stored.
I survived time in the US Army doing non conventional tasks in my youth and this is a Piece of Cake in comparison. No one yelling at the overweight cadets and running in circles around the rest of us, snacking. Yes, the good old days.
Getting up the ladder and down is something to write home about, or at least post. So here it is. My two 170 watt Solar Panels are sucking the energy from the Sun's excess energy on the top of the Oliver is complete.
Next... the 2019 Airstream. Stored in the RV Garage, No leaf blower needed, for either trailer. That is a plus. I am rested and see what damage I can do.
Clean your Solar Panels. Like wiping mud off your glasses so you can read this.
Oh... never cleaned the Salt and Grit off of your Solar Panels? No wonder you replace your batteries, often. Today is the First Day of your Life. Wake up. Bears Hibernate, Neanderthals Hibernate... after this is done.
Yes, I must disclose I have Costco Stock. Oooooh Weeee.
Happy New Year... and if you do not understand any of this. Sober Up.
