03-23-2010, 03:45 PM
#21
2008 25' Safari FB SE
Victoria
, BC
Originally Posted by dufferin
Remove the vent cap... you may find a square gasket (the one used for 70'S square alum square vents) ... I bet you a beer on that...
Yes in fact the gasket was not big enough for the footprint of the Vent cap. It was a kind of trapezoid square shape & clearly did not provide a seal against the elements.
How stupid is that?
A/S needs a little bit of a whack up the back of the head for some of their stupid design flaws.
-evan
03-23-2010, 03:52 PM
#22
Islay - 63 O.
Montreal
because they use an old 70's stock... and it doesn't match at all the round plastic vent. I was sure yours had the same since I could noticed the "Wave" at the base of the vent.
It is 100% leak guaranty!!! And it's factory. I started a thread couple of years ago about that. But be sure it was leaking since day 1.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
https://rvcampreview.com
#23
Victoria
, BC
Originally Posted by Jammer
Excellent work, and a great photo essay!
A couple of questions:
1) What is the rated wattage of the combined panels?
2) Any concerns about condensation or frost accumulating on the panels from the vents?
3) Have you thought about some sort of spoiler for the forward edge of the panels to minimize drag?
Thanks Jammer.
I've enjoyed some of the other installation blogs I've read here & thought this subject could use a few entries...
1. The panels are rated at 100 watts but according to AM Solar testing can with their higher output voltage produce as much as 130 watts under ideal conditions...
2. The panels are supposed to be weather proof & seem quite well sealed against the elements bot topside & underneath. (They have a 25 year warranty) I don't think there is much concern about condensation underneath...there is quite a bit of breathing space underneath & around the edges. My only concern is that we might trap some off-gas odors from the tank vent near the bathroom vent, but we'll see how that goes.
3. Yes. I was thinking that a spoiler would make a lot of sense and make for a cleaner presenting edge with improved aerodynamics.. If you know of any low profile ones that you think could work, please let me know.
-evan
03-23-2010, 04:00 PM
#24
Victoria
, BC
I saw your thread & it was what prompted me to simply replace the caps instead of just re-caulking around them. I used a wheel barrow inner tube to create my own gaskets & I expect the waterproofing to be good for some time as it isn't dependent on the caulk alone.
I think this is ridiculous of A/S to try and save a few pennies but risk the integrity of their products (literally in terms of withstanding the elements and in terms of their reputation).
I have had 5 different leaks in the year & half that I have owned this unit 2 because the caulk lines were incomplete, one because the caulk over the bedroom curb-side window cracked & failed & two with this plumbing vent issue.
I think I am on top of this issue & am much more careful to keep an eye on any cracking caulk but this was not what I expected to have to do with a brand new trailer of this caliber.
I am not sorry to have this unit but I am disappointed in the shoddy QC of Airstream.
-evan
03-23-2010, 04:35 PM
#25
2016 30' Classic
Trenton
Thanks for such an excellent photo narrative. I'm planning to install the same AM Solar system with only two panels sometime within the year and this thread has given me a lot more confidence in my ability.
I'll be interested in hearing how panels perform in your boondocking adventures.
Since an RV has a kitchen and bathroom it's considered a 2nd home and eligible for a 30% tax credit on renewable energy systems. Bonus!
Steve
03-23-2010, 05:15 PM
#26
2006 28' Safari SE
Mississauga
, Ontario
Excellent material. I have two AM solar panels being delivered tomorrow so this will be more than helpful for my installation process on 2006 Safari SE 28. Love the panel placement - I had not considered placing over the vents.
03-23-2010, 05:26 PM
#27
2007 25' International CCD FB
1961 16' Bambi
1956 16' Bubble
Potrero
Thanks Evan, waiting for our AM Solar panels
Wow!, Evan,
Thanks for that great step by step.
Pics cleared up much of my questions. (Visual guy...)
AM Solar shipped to us yesterday, the panel system arrive this week. We went with the same set-up and combo, only got two panels which will be mounted port and starboard with the centre left open for now.
As we have twins in our International, the run will be a bit different however the location concept will be the same.
I was already thinking of a forward and aft "winglets". Just a snap-on aluminum " foil" to taper the leading and following edge of the panels, you know, a bit more airstream. (AM Solar, an easy add-on option).
Again, thanks, and we'll let you know how our install goes, how our 4 battery boondocking set-up works on the TinDen.
Stream Safe,
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1961 Bambi, 16' California
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
( View all of elfirebob's images)
03-23-2010, 09:36 PM
#28
Victoria
, BC
Thanks Tin Loaf.
I'll be sure to report back on how well the system performed. We hope to do a lot of boondocking in the next 4-5 weeks.
-evan
03-23-2010, 09:40 PM
#29
Victoria
, BC
Good luck with your install.
I don't know whether I said it clearly enough but the quality & design of the AM Solar kit was excellent. Everything was shipped properly and complete with good instructions.
(I have no financial interests in their company BTW but I should be counted as one of their very satisfied customers. I hope you will be too.)
-evan
03-23-2010, 09:45 PM
#30
Victoria
, BC
Originally Posted by elfirebob
Wow!, Evan,
Stream Safe,
Thanks Bob.
It looks like lots of people have the same idea around here.
I'm only guessing but at your lower latitude and increased frequency of sunny days, I'll bet two panels will give you plenty of power. We have less sun and at a lower angle so I thought I should go for a three panel system.
Are you aware of any sort of spoiler system? Does AM solar have something? I would be very interested in what you come up with as the setup is just begging for some sort of 5 inch high sunroof style spoiler to block the wind from getting under the panels & smoothing out the forward edge cutting into the wind.
4 batteries should give you lots of storage. Where are you putting the 4 batteries?
Good luck with your install & happy camping.
-evan
03-24-2010, 09:54 AM
#31
1961 16' Bambi
1956 16' Bubble
Potrero
Elfirebob's solar layout
Evan,
I don't know of any specific streamline products for the panels, I'm still thinking about that.
Due to the layout of our racks, there is a huge dead space forward, where all the electronics are for additional batteries (AGM).
The controler /display too may end up on the face just below the drawer.
I never heard what you found out and why you did not use the "triangle void" down run at the forward bathroom bulkhead?
I have to agree with you, to minimize the wire run and keep the guage wire I want, drillng the hole through the roof will be the toughest part. We may stall our trip a day for an install. Heading for Arizona...Picacho, Roper, Patagonia, and Tucson. I't would be good test run for the system.
Again, thanks for your efforts in posting all that detail.
Stream Safe,
Bob U-
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
03-24-2010, 10:18 PM
#32
Victoria
, BC
Evan,
Stream Safe,
Bob U-
Hi again,
A comment you made on another thread got me thinking. You mentioned that Solar panels , Bikes & BBQ's were prime targets for thieves. Looking up at the panels from street-side & from the front, I thought those no-tool fasteners made the solar panels look a little too portable and also probably would add to turbulence. So today, I replaced all those knobs with hex head SS bolts. The whole thing looks cleaner & a lot less portable.
I think that spot you've chosen would work well. I don't know whether the controller has any relay clicks or sounds to it that would be a nuisance...? The Twin Layout strikes me as quite practical. I guess you have more space for batteries but I suppose we could have some AGM's under the bed. I've been told you can't properly combine the different types of batteries (e.g. wet lead acid with AGM's) so until I find out how well our current system works, I wouldn't want to take the next step up & replace the GC batteries with AGM's.
Lewster has been a big help in providing me with feedback & advice. He feels that the one real deficiency in my setup was going for the GC batteries instead of AGM's He feels strongly that AGM is a much better way to go. That would have been a much more expensive option for me though & so balked at that. I'll see I guess. We aren't running an inverter & don't have a TV or anything so besides the lights, fans & furnace& a little bit of electronic usage (Laptop, radio etc.) I'm hoping we'll have enough juice to be able to stay out as long as we want with water (waste & supply) becoming the limiting issue.
I considered using that dead space you refer to but I wanted the controller in a more visible spot as well as the ability to monitor the entry point of the wire through the roof to make sure there were no leaks at any point in the future. Now that I have the Rooftop Combiner box in place though, I don't think it's that likely to leak anyway. Although it seems rather alarming to drill through the roof, it really isn't as vulnerable a hole as those #$%&*#@ plumbing vents. When you're up there doing your install, I'd suggest that you take a long hard look at yours.
We're heading out to the deserts of Utah soon for a few weeks & hope to have a chance to really stress the system.
I'll be interested to hear how you find your system works for you in your adventure...
All the best.
-evan
03-25-2010, 04:07 AM
#33
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area
, Tennessee
Very nice thread, Evan. With solar panels in my future for the '56, your thread has been a good resource. Even though I personally won't be installing them, it's nice to see an installation like yours.
03-25-2010, 07:25 AM
#34
1956 22' Flying Cloud
Dallas
Terrific thread
Thanks for this very informative thread and photo essay. For those of us contemplating solar installation, your thread is very helpful. Hank
03-25-2010, 10:21 AM
#35
1958 26' Overlander
Mesa
Although AGM batteries are fine in their own right and give you more options, I don't see how choosing to go with Golf Cart Batteries is a bad choice. LOTS of RVers use GC batteries, myself included.
I respect Lew's opinions quite a bit (he helped guide me in installing my Freedom 10 Inverter-Charger) and would be interested to know exactly why he said AGMs were a better choice.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
03-25-2010, 03:27 PM
#36
1961 16' Bambi
1956 16' Bubble
Potrero
Some final points
Evan,
Just some final points before we head out in the morning;
-Great Idea, I have to agree that the knobs make it look easy.
-Had not thought of that, I’ll call AM Solar and ask about noise, wait a minute, with all the snoring going on…
I've been told you can't properly combine the different types of batteries.
-We plan on installing all four next year.
-Lifestyle has a lot to do with length of stay, we’re pretty conservative with cooling Corona’s the priority.
-For all the reasons you state, the ceiling/roof hole will be the same, thanks.
-Will do, I’ll let you know if the ‘70s square gasket is found, kinda like Geocaching…
-Have fun, love most of Utah…Colorado, Arizona, New Mexico.
-We’ve decided to do our install after getting back from this run, panels should arrive today maybe. We will let you know and post some “twin bed” install points. (I modified the beds to come together, kinda like a queen for really cold nights!)
Stream Safe,
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
03-25-2010, 05:44 PM
#37
Master of Universe
Grand Junction
Evan,
Good series of posts on your installation. I have some questions:
1. The soil stack (the black tank vent) will give off some acidic fumes. I think they will be mild acid fumes, but over time it may have an effect on the bottom of the panel. Have you considered that?
2. I see an access panel over the battery buss compartment—did you cut that out? I don't remember such a panel under our mattress. It's a good idea because otherwise it's very hard to get to the compartment.
3. Those vents have a history of leaking pretty quickly. I'm going to get up there and look at mine soon, something I have been avoiding for as long as I can.
4. I like the way you raised the top of the battery box. I hope to get an in-person look at the adaptation when you are in the Southwest in a few weeks. I don't know the answer between AGM's and Golf Cart, but I've read some battery threads which made me feel insane after a while.
5. It looks like there's plastic over the carpet under the bed by the exterior access door—good choice. That door can lead a little and I taped down Visqueen over the carpet long ago.
Gene
03-25-2010, 05:56 PM
#38
2008 25' International CCD
Wallisville
Outstanding post eheffa!! Thanks for the "guided tour" through your installation. Your post illustrated quite a few of the my concerns regarding solar panel installs. Kudos.
Joe
03-26-2010, 10:24 AM
#39
Victoria
, BC
Thank you Sugarfoot.
-evan
03-26-2010, 10:42 AM
#40
Victoria
, BC
Originally Posted by CrawfordGene
Evan,
Gene
Hi Gene,
Thanks for responding.
You raise some good points.
1> Not that I was that clever but more because of the location, the Black Water Vent is actually not covered by a panel but sits between & pretty close to the Curbside & Center panel.
Here it is just peaking out from between the two panels.
As to whether the gases emitted are going to be acidic & corrosive...hmmm I guess it isn't in use that much of the year but we'll have to see. Maybe I'll have to modify things if it proves to be a problem.
2> The access panel was there from the factory. It's not that obvious at first glance.
3> Yes. It's tempting to hope for the best & if it ain't broke...but, I think there is a real design flaw in these. The integrity of the water barrier is totally dependent on the caulk. If I hadn't drilled my "test" hole, I wold not have know that the insulation was sodden there. The aft (gray) water vent was the real leaker. The Black tank vent was only just starting to leak. I was surprised how easily the caulk came of using some of that Bleche White stuff to soften it up. With the new metal caps, I had to fiddle with the top of the pipe / cap interface to get rid of the natural gap between the pipe top & flange. I put in expanding waterproof foam gasket & caulked it all over before putting on the "lid". It's a tight fit. Hopefully it will allow some flex without failure.
4> Thanks. I hope to show you my high school metal work project in person... ;-)
The AGM's are probably better but unless you are really stressing the limits of storage & discharge, I'm not sure that they make sense for everyone. Obviously, if there is any plan to go to 4 batteries with at least 2 in the living compartment then AGM's would definitely be the way to go.
5> We seem to be singing off the same page. One of the first things I did after gasping in surprise to see carpet on the storage locker floor was to cover it up with some rubber mat. (Who decides these things?)
Thanks again Gene.
-evan
