Charge to 100% and disconnect.
englewoodfl, if you charge your AGM’s to 100% then disconnect you’ll be fine - they won’t self discharge much unless you’re planning on leaving them for over 6 months.
We I say disconnect, I’m not talking about the switch by the door. You need to physically disconnect either with a master switch or removing the battery cables.
The photo below shows the Blue Sea disconnect I installed with our AGM’s before upgrading to a Victron MultiPlus II and Battle Born GC3.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
