Old 03-30-2020, 10:27 AM   #1
2020 25' Globetrotter
Malibu , California
Solar fuse in pre-wire
DYI 4 100 watt panels in new globetrotter. Looking at adding in line fuse to each panel as assume there is not a fuse in AS pre-wire?
Garfish is offline   Reply With Quote
Old 04-06-2020, 06:25 PM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I did not put a fuse on my solar panels because I believed my Airstream's electrical diagram in the owner's manual that stated there was a fuse installed. When I researched the Zamp Rooftop Box that is installed on my Airstream, the descriptions said there was a 40A fuse installed. Here is a marketing picture of the Zamp rooftop box showing the fuse installed: https://www.rvupgradestore.com/3-Por...-p/19-2768.htm I believe Uncle_Bob added a fourth SAE port to his and said there was a 40A fuse. But recently, Kalashnikov had a problem with his prewire so he removed his Zamp rooftop box and there was no fuse installed. Therefore, I do not know how to answer this question. I continue to use my rooftop box with the assumption there is a 40A fuse inside.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Location of Solar Pre-Wire. Where are the wires? kscherzi Generators & Solar Power 10 06-02-2013 04:06 PM
2010 28' International Solar Pre Wire ?? Streamer1492 2006 - 2010 International 1 09-23-2012 03:02 PM
Solar pre-wire on a 2005 19' Bambi CCD JDL Generators & Solar Power 23 12-22-2010 05:50 AM
Solar pre wire bwaysteve Generators & Solar Power 7 11-21-2010 07:06 PM
Solar Pre-wire 2008 Safari 25 FB SE - Good enough? eheffa Generators & Solar Power 3 10-23-2009 10:30 AM
