RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-22-2020, 03:39 PM   #1
The Joymobile
2011 22' Sport
MERIDEN , CT
Solar for 22' Sport FB
I have a 2011 22' Sport FB. Plan to install 200w on the roof. It's October here and the weather is turning...so these will go on in the spring. Pictured are two HQST 100w mono panels. They're smaller than most 36"x26." They are presently priced at $80 each.
I'm just dry fitting them today. Need to either modify the existing outside brackets or fabricate some new ones. See that some commercially available tapered ones may be available from Zamp. We'll see what is the easiest.
Regarding the 3" gap in the center due to the brackets butting into each other, I'm considering either offsetting them or fabricating a mounting rail so the panels have about 1/2" gap. If I offset the brackets, then will be difficult to caulk around them. The bracket I envision, would be fixed to the roof with adhesive tape and then bolted to the panels.
ID:	381512   Click image for larger version
ID:	381514   Click image for larger version
JeffofCT is offline   Reply With Quote
can three of these ZS90 Solar solar panel fit atop a 22fb sport waninae39 2005 and newer - Bambi all models 1 06-27-2018 08:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 07:04 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 10:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 08:11 PM
