Old 08-06-2020, 09:15 PM   #1
Xxxxxxxx , Xxxxxxxxxxx
Solar ends at 12v card
Bought trailer used.2016 27’ international . Solar comes off roof, thru fridge vent bypasses water pump, continues under floor and pops up at the power center. Someone connected the solar wires to the 12v distribution card . Positive to the big red +cable on the top left of the card and the negative solar wire to where the big white wire clamps on to the card on the top right. The solar works well but I expected solar wires to go direct to battery’s. Is this ok?
Roll me away is offline   Reply With Quote
Old 08-06-2020, 09:40 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
As long as the solar controllers output is tied into the DC system technically it will charge the batteries. Now with that said there can be inefficiency's in the system wired that way.
12v
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
12V dead ends.. '69 Overlander Luc_DK Electrical - Systems, Generators, Batteries & Solar 4 08-07-2012 07:49 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
