02-01-2020, 01:20 PM
2019 23' International
Portland
, Oregon
Soft start for 23FB
My dealer says that if I have them add the soft start to my AC it'll run on my Honda EU2000. Anyone out there actually tried this?
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
02-01-2020, 01:22 PM
2012 25' FB International
Trent Woods
, North Carolina
Lot's of threads on this. The answer is yes, but don't have other AC loads on.
Larry
02-01-2020, 01:37 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Yes it will.
02-01-2020, 01:57 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Yep. Works like a champ
02-01-2020, 03:28 PM
2002 30' Classic S/O
Fleming Island
Make sure you are getting the EasyStart brand. There are many "soft starts". In my opinion, the EasyStart is the best.
Al
02-01-2020, 05:57 PM
2017 30' International
Broomfield
^^^ EasyStart. It is the absolute go to unit. 30 minute install.
02-02-2020, 09:20 AM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Honda- Micro Air
Yes it will start and run it. Works well. However It can“ SCREAM “ on hi idle if a hot day under heavy demand like if TW turns on anything else. Refrigerator must be on propane. So I end up bringing the companion 2000 along anyway.
02-02-2020, 11:14 AM
2020 27' International
St Augustine
Which honda eu2200 do you use?
the companion with the 30 amp plug or the regular one
I am guessing the one with the 30 amp plug
but i want to be sure or could you use either one with a plug adaptor?
thanks
02-02-2020, 11:45 AM
Broomfield
Either one will work. They put out the same power when running as a single unit, regardless of the outlet type (20A vs 30A).
02-02-2020, 11:46 AM
2017 22' Sport
Renton
Generac 2200I as well!
The Generac 2200I also works wonderfully on the AC or the microwave....but not both at the same time
02-02-2020, 12:03 PM
2004 22' Safari
Albuquerque
, New Mexico
There are several brands out there. I have an EasyStart and and it runs the AC just fine. I don't have many other loads on AC, and I keep the toaster put away when I run the AC
02-02-2020, 12:07 PM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Just tagging on here. I had the easystart on my 23FB and it worked fine with my Honda 2000. I just switched to a 25 FB with a single 15,000 AC. Will easystart enable the larger unit to run on the Honda 2000? I’m sure it’s been mentioned, but I never paid attention. I never thought I’d switch trailers..
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
02-02-2020, 01:00 PM
2016 28' International
Trois-Rivieres
, Quebec
Exactly, you get the model with the 30A plug if it's your second unit, connected to the first. I have the EasyStart on one of our ACs (15K btu) and it's enough for our needs. So one 2200W generator is enough for us.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
02-02-2020, 01:08 PM
Trent Woods
, North Carolina
Works fine on my 25
Larry
02-02-2020, 02:43 PM
Wildwood
, Missouri
Originally Posted by lsbrodsky
Works fine on my 25
Larry
Thanks Larry. Your 25 was one of the reasons we decided to go to 25 from 23. I should have asked you while we were camped next to you in NC.
2020 25GT FBT
02-02-2020, 08:08 PM
2019 30' Classic
Baltimore
, Maryland
warranty issue
If your AC is still under warranty, I was advised at JC that Dometic will void any remaining warranty. Worth calling Dometic to make sure is you have any warranty left.
02-02-2020, 08:42 PM
2017 23' Flying Cloud
Port Richey
First mod we did on our 2017 Flying Cloud 23FB. Works like a charm.
02-02-2020, 09:45 PM
2015 27' Flying Cloud
Truckee
Trouble with mine. Operator error?
To piggyback on this thread, I have a 2015 FC 27FB. Added Easy Start and have a Honda EU2000. When I tried running the AC off of the Easy Start, it would initially kick on, but then turn off and flash an E7 code on the thermostat. It would then kick back on. It would do this every few minutes, never really getting going and the trailer cool. Any ideas why? I am not very knowledgeable with this stuff, nor have I had much time to troubleshoot - we tried it once while camping during the rolling blackouts in CA this Fall, but then had to high tail it out of where we were due to fire danger. Thanks.
02-03-2020, 08:55 AM
UnklJoe
2015 28' Flying Cloud
Box Elder
, South Dakota
Hi, not to hijack this thread--but I really like the rear hitch and generator holder on Glampman's post picture. Is it custom made or is it a retail product? Details would be excellent!
02-09-2020, 10:11 AM
Columbia
, South Carolina
Yes it will. There are some load sharing tradeoffs. You can’t run your microwave or refrigerator when your AC is running. Also those two will put a power overload on your Honda 2000.
