Old 02-09-2020, 11:49 AM   #21
2012 30' International
Saskatoon , Saskatchewan
Easystart
I installed the easystart on our 2012 30' International Serenity, 15,000BTU.
Our inverter brand is by Kipor, a 2600 W. This is a Chinese built generator but one of the higher quality brands.
First making sure I did the recommended 5 AC starts while on shore power, our generator runs the AC while on Eco-mode and only slightly increases the revs.
Never tried it in real hot weather but it works fine and even performs better on shore power.
arstrmlvr is offline   Reply With Quote
Old 02-09-2020, 12:11 PM   #22
G-Ranch
G-Ranch's Avatar
1970 25' Tradewind
Smyrna , Georgia
Originally Posted by SGandMT View Post
To piggyback on this thread, I have a 2015 FC 27FB. Added Easy Start and have a Honda EU2000. When I tried running the AC off of the Easy Start, it would initially kick on, but then turn off and flash an E7 code on the thermostat. It would then kick back on. It would do this every few minutes, never really getting going and the trailer cool. Any ideas why? I am not very knowledgeable with this stuff, nor have I had much time to troubleshoot - we tried it once while camping during the rolling blackouts in CA this Fall, but then had to high tail it out of where we were due to fire danger. Thanks.
May have to turn off / isolate battery charger - any other load.
G-Ranch is offline   Reply With Quote
Old 02-09-2020, 12:37 PM   #23
2017 22' Sport
Renton , Washington
Originally Posted by UnklJoe View Post
Hi, not to hijack this thread--but I really like the rear hitch and generator holder on Glampman's post picture. Is it custom made or is it a retail product? Details would be excellent!
Hi! Minus the generator, that is all from Torklift. They added a 2 inch receiver, and I bought the load and lock generator carrier which slides into the receiver.
Not shown, is that I recently got them to do very sturdy 3 inch lift as well, which allows more ground clearance and additional height for waste discharge.
https://www.etrailer.com/Hitch-Cargo...t/TLA7901.html
Glampman is offline   Reply With Quote
Old 03-09-2020, 04:09 PM   #24
2019 23' International
Portland , Oregon
So... with the easy start can the AC run on 15A shore power?
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 03-09-2020, 05:20 PM   #25
2019 22' Sport
Carlsbad , California
Yes, mine does.
Prettygood is offline   Reply With Quote
Old 03-09-2020, 05:21 PM   #26
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"So... with the easy start can the AC run on 15A shore power?"
Ours runs on a 20 amp AC when I use a short heavy cord. I do not know if it will run on a 15. I do not think so. I was seeing 15+ amps the last time I ran mine on a generator and was checking voltage and amps. I think our AC is 13,500.
I would not run it on a 15 amp circuit even if it seemed to run on it. I do not trust the 15 am connectors and cords I do not want to fry the compressor. I use a PD surge protector that shuts down for low voltage and I keep a voltmeter plugged into a circuit to see if I get a voltage drop or if the circuit has enough voltage. The surge protector also forces a 2 min delay for restart for any interruption. That is an important feature. Especially when you are fooling around with it and on marginal power.
Old 03-09-2020, 07:56 PM   #27
Portland , Oregon
Thanks. I assumed that was the case, but worth asking.
2005 Yukon XL
Soft start for air conditioner in the DFW metroplex cfishii Our Community 9 07-18-2019 08:09 PM
Soft start installation in the DFW Metroplex cfishii Electrical - Systems, Generators, Batteries & Solar 0 07-06-2019 02:27 PM
Soft Start Kit For A/C 3bcamper Sprinter and B-van Forum 49 06-16-2018 09:49 PM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
