Kim, I'll try to answer your question. It looks like your original controller has two posts for attaching cables, and your new one has you insert the wires into a "hole." You are wondering why the change.
Using posts, you have to crimp a terminal onto the wire, then tighten that terminal to the post. The post is exposed, so there is a possibility of someone or something touching both connection points accidentally. That's not a good idea! Using the "hole" method, you simply insert the wires into the proper point and tighten the screw. That screw is usually recessed, at least a little bit, so that it is harder to accidentally touch both terminals. Somewhat safer.
I have both types of connections, and both work well. With either one you have to make sure that connections stay tight. Generally, if a terminal is properly crimped on it won't ever come loose. It has been known to happen, though, that a terminal appeared to be properly crimped on, but wasn't, and later came loose. Good to check every connection point regularly.
David Lininger, kb0zke
7490
2021 Flying Cloud 30 RBQ
