The solar control panel and your trailer's built-in battery voltage reading are independent, and whenever the solar system is charging the battery voltage should high enough to get a 100% reading. That doesn't mean your batteries are at 100% though, just that the solar charge controller is outputting that voltage.
To get a true view of your batteries' condition with a voltage based monitor, you have to disable all charging sources and all loads for half an hour or so. Then once your batteries stabilize you'll be able to see the actual level of the batteries.
If you have a shunt based battery monitor connected, then perhaps your batteries are fully charged. In this case the fact that your solar charge controller shows various amp levels likely reflects the load that is being drawn from the battery bank. Once your batteries are full, the solar charge controller will open/close the current flow (amps) as needed to power whatever devices are turned on while keeping the batteries charged. If you turn on lots of
12v stuff in the trailer when it's showing 0 amp you should see the number increase to keep up with the increased load.
