I can't speak for you stock quick connect LP gas feeds, but the limit could easily be the rated BTU output of your regulator(s).
Mine is a 287.5K BTU auto change over regulator which is common sized for many applications. (Amazon
https://www.amazon.com/dp/B0DK626918...fed_asin_title ) that I replaces my old system with.
On my 1985
Sovereign 25' there were no Quick Connects and I added one on the curb side where there was already a TEE that fed the (Removed) stove and at the rear feed to the water heater replacing a union with a TEE.
I added another Quick Connect at the rear for my generator.
The feed from the regulator is a 5/8" flex to the 5/8" copper to the first tee in the curb side.
From there the rest of the plumbing is 3/8" all the way back to the added QC at the rear bumper.
I have operated the entire trailer with a Pulsar 2200 bis dual fuel generator that puts out about 2000 watts on LP gas.
I swapped out the noisy and power hungry Penguin A/C for a more efficient Tosot Eco Cool with a soft start unit. This small generator runs the trailer and A/C pretty well being fed from the rear QC and a 25' 3/8" rubber flex line so that I can get some distance from the trailer for noise. The 25' electrical cable on my trailer also exits the rear bumper so both can be ~25' away.
Most likely the Predator will get enough gas to operate as well.
