Old 01-23-2019, 05:30 PM   #21
1971 27' Overlander
Kansas City , Kansas
Agreed with the last post.
If you have purchased a battery worth 1000 bucks, you want a good charge controller to maintain maximum life. This means a charge controller with programmable parameters. Even the defualt lithium settings Victron provide are in no way ideal. A controller for lithium batteries needs to have the ability to adjust the float and absorbtion stages of charging so you can effectivley turn them off. A programmable charger does not need to be specific for lithium batteries.
For example, my settings are as follows: Absorbtion: 14.2 volts, absorbtion time 1minute (off), float 13.15 volts (lower than full charge state). Due to the fact battle born use an absorbtion type charge for cell ballancing, I will adjust the settings every once in a while to allow for this.
Shermy1987 is offline   Reply With Quote
Any updated portable solar panels recommendation? Vitaver Electrical - Systems, Generators, Batteries & Solar 15 10-24-2016 04:04 PM
Security for Portable Solar Panels CAV Generators & Solar Power 11 09-01-2016 07:26 AM
Portable Solar Panels Fancypantsas Batteries, Univolts, Converters & Inverters 8 08-09-2016 10:43 AM
Solar panels vs portable generators ashe Electrical - Systems, Generators, Batteries & Solar 19 01-19-2015 07:18 AM
Portable Solar Panels migriffin Sprinter and B-van Forum 31 04-11-2014 06:56 AM
