Portable panel suggestions for Airstream a-frame connection & Bluetti ACP200P?
Hey all, our 2021 Flying Cloud 25FB Twin is coming (soon? I hope?) with the factory-installed solar, but I've also got a Bluetti AC200P. Looking for a set of portable panels that'll give me flexibility to attach to either one....but there's some challenges, and I'm not yet familiar enough with the systems/market-available options to know the best path.
The Bluetti wants 35-150v in, max 700W, max 12A. It has a built-in controller, so it takes unregulated panels.
The A-frame solar port goes direct to the battery, so it needs regulated panels, or, I assume I could wire it back through the onboard controller, or use a stand-alone controller....I'm unclear what happens if I have portables connected and I'm getting power from the roof panels and the portables at the same time. I'm also guessing I'm aiming for somewhere between 13 and 18v for the airstream port (it'll ship with the AGM batteries, but Battleborns are in the near-future plan).
So the main question: are there portable panels out there that are easy to switch between a regulated/unregulated feed, and that can be easily switched between a serial and a parallel configuration, so I can hit the required sweet spot for both the a-frame connection and the higher-voltage/lower amperage Bluetti solar port, as my needs shift?
Thanks for any guidance.
