Old 03-10-2019, 03:31 PM   #1
2019 33' Classic
Douglas , Alaska
Opinion on best inverter generator
Hi,
We will be picking up our 33' 2019 Airstream Classic in several months and will become full-time RVers and are asking recent Classic purchasers/owners what the best inverter generator is? After doing research this morning it appears that at least a 3500 watt may be sufficient, but we want to make sure that we are buying the sufficient wattage/amps. Any advice will be appreciated. We have reviewed the Champion, Honda, Westinghouse and Briggs/Stratton. Thank you.
D&B
WanderGators is offline   Reply With Quote
Old 03-10-2019, 03:46 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Beside wattage you meed to consider size, weight and noise.
Running one AC I would go for 2 Honda 2000i with the parallel cable.
Garry
Old 03-10-2019, 05:29 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
I agree with the last post. 2 Hondas run in parallel. They are not heavy. A 3500w will be close to 80 to 90lbs. Not easy to lug around. And sometimes you might just use one; especially if you don’t run the AC. I like my little Hondas because I use them around the house as well. Very quiet and very dependable.
Champion 3500 seems to be a way many go on this forum.
Daquenzer is offline   Reply With Quote
Old 03-10-2019, 05:41 PM   #4
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
You should also consider having an Easy Start added to your air conditioner unit(s).
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 03-11-2019, 08:43 AM   #5
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I prefer the sound of a single larger generator over a pair of smaller generators. If money was no object, I'd own a 3000W Honda converted to propane from Genconnex https://genconnexdirect.net/honda_pr...tm#xl_EU3000is. To me, this is the best sounding generator on the market.
But since I'd rather not spend spend $3,000 on a generator, I bought an $800 Champion 3400W Dual Fuel Inverter generator instead. My Champion generator is slightly less pleasant than the Honda. I make up for this slightly less pleasant sound by running the generator in my truck bed and by using it very infrequently since I self-installed 400W of solar for $2,000. My Champion generator was only used for 10 hours while my solar provided the power for the rest of my 100 days of boondocking this past year.
Bottom line, my 400W of solar is completely silent and my preferred power source. I'd rather spend $3,000 on solar, including a Champion Dual Fuel Inverter generator, than spend $3,000 on the best sounding generator on the market.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Old 03-11-2019, 09:23 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
For about ten years, we had two Honda 2000's. They worked flawlessly. It was nice to have the option of using one, or both, depending on the situation. The only downside to these Hondas was the size of the fuel tank. It was difficult for them to run all night with air conditioning on the one gallon fuel capacity. We did have a separate fuel tank to solve this problem, but it was a pain to set-up. Much of our generator use was for an overnight stop in a parking lot.
About two years ago, we sold the 2000's and got a Honda 3000. This has filled the bill better for our generator use. With it's four gallon gas tank, it can easily run all night.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 03-11-2019, 09:26 AM   #7
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
I've been really impressed with the specs and reviews for the Westinghouse 4500 dual fuel inverter generator. Don't own one yet but will be buying one soon from Home Depot because there is a store nearby and that will simplify the return process if I get a dud or it is just a piece of junk. They are also available at Samsclub, Amazon, and other online sellers. Here's a link: https://www.westinghouseoutdoorpower...ts/igen4500df/
Check out the YouTube reviews also.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 03-11-2019, 09:29 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Honda, Honda, Honda AHHHHH Save yourself a wack of money and pick-up a Champion Dual Fuel 3400 fantastic generator - runs on gas or LP !
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 03-11-2019, 09:35 AM   #9
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
The two best brands are arguably Honda and Yamaha.
The Yamaha 2400ishc is small enough for one person to lift and large enough to run one AC unit (and not much else). It's also quiet and well built. This model is able to take short burst demand where other's of a similar size can't. Honda does not make a similarly sized model.
If you want to be able to run your AC, refrigerator and a coffee maker at the same time, you'll need something larger, but it will take two people to move it.
The Yamaha EF6300iSDE is large enough to comfortably run a large rig. If you have 50 Amp service, you could split the 240 Volt into two 30 amp legs using an adapter. The Honda EU7000IS is the next step up from the Yahama.
Amsterdamer is offline   Reply With Quote
Old 03-11-2019, 10:40 AM   #10
brookhaven , Georgia
Why exclude the Yamaha 2000’s? They have a longer run time than the Honda 2000’s. Get two of them and a parallel cable. Two connected together on eco mode are quieter than one running fast. Two will run the AC with power to spare.
coasttocoast is offline   Reply With Quote
Old 03-11-2019, 10:51 AM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
AirMiles
I like your logic and I completely agree.
Dan
Old 03-11-2019, 11:06 AM   #12
VaTravelers's Avatar
Virginia Beach , Virginia
Two Honda EU2000 (or EU2200I) converted to propane by Genconnex plus EzStart - works great for running one A/C on one generator - my biggest pushback against a single 3000 is weight. Conversion to propane is worth considering.
VaTravelers is offline   Reply With Quote
Old 03-11-2019, 12:07 PM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Only Blue & Red experience...
Blue, Yahama 1000w, 18 Seasons... no problems at all...petrol only.👍
Red, Honda 2000i, 12 Seasons... so far, no problems at all...LP & petrol.👍
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 03-11-2019, 12:48 PM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hold on just one minute there - you mean to say you can use two DIFFERENT products at different times for different purposes and have a good experience with BOTH of them???? You mean - itís not an either/or???? Thereís no a single right/best/most awesome product????
What kind of fresh heresy is this?!?!?
Old 03-11-2019, 01:15 PM   #15
2007 22' International CCD
This forum is well stocked with us heretics...especially the Department of Overkill Engineering...
Old 03-11-2019, 01:20 PM   #16
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Lots of good advice and disagreement here already, to "help" you with your decision!
Your use model and travel location needs are important to consider. Also, do you want to carry gas or propane in the back for your generator? Important to consider.
Not sure how often you will need the AC, or if you need 2 AC's running at the same time? But if you expect to use the generator to drive them both, the Easy Start from Micro Air is a good suggestion; it will help take the initial "load" off of your AC's during start/cycle. Many of us who have generators when boondocking can get by with one AC depending on our locations. I know if we are going somewhere hot like Florida or Texas in summer, we try to find a place where we can plug in to shore power...
Honda, Yamaha, and Champion all have followings here, as you see....weight and fuel are important considerations. We moved to propane last year with the Champion Dual Fuel...weighs in at 95lbs, and we can hook to our propane outlets on the AS but I also carry a 20# LP portable bottle.
If money were no object, I would consider the Easy Starts and a couple of Honda2200's with the Genconnex propane conversion...gives you lots of flexibility, they are quiet, and only 45lbs each. With the parallel kit, and the Easy Starts you can run both AC's if needed also.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-11-2019, 01:21 PM   #17
greenflag's Avatar
2016 30' International
Quartz Hill , California
2 Honda 2000's for 12 years. Flawless operation and quiet. I can lift them into the back of my truck by myself. Hook them together when I need air conditioning.
greenflag is offline   Reply With Quote
Old 03-11-2019, 01:56 PM   #18
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Here is my scheme for cooling a 34 slide out with 2 A/Cs. 600 ah Lithium batteries, 3000 w inverter, 800 amp solar, MicroAir EasyStarts, Yamaha 3000iESB propane genny. For lunch stops just run the front A/C on the inverter with the galley curtain closed. For longer periods run which ever A/C for the zone you are in. If you need both, run the A/C on the inverter and the second A/C on the genny. Or, with the EasyStarts you can run either or both A/Cs on the genny. If you are a little short of power there is a load sharing device that will prioritize your A/C loads. The propane conversion is made much easier with an A/C connection and a separate quick-connect propane connection at the front of the trailer. We sure enjoy our setup.
guskmg
Old 03-11-2019, 03:03 PM   #19
Mollysdad's Avatar
I should have just kept walking.
When I saw we got all of 4 posts before someone mentioned "easy start", I definitely should have hung up.
"Best" is subjective.
Best value?
Best resale?
Best dealer network?
Best sound deadening?
Best amp output?
IMO, I'd have a Honda 7000 if I could afford it and it fit in my truck.....I don't.
I don't like pull starts. I do like Hondas, so I have a EU3000is.
Here's the odd thing. Yes, it's heavy; yes, it's expensive (I got it used) and I have yet to actually use it camping.
I just know if I left it home, I'd tear a hole in the fabric of the universe and it would punish me by losing power everywhere I went.
Old 03-11-2019, 04:01 PM   #20
Harbor Freight 3500.
Allegedly quieter than the Honda.
Under $700, so 1/3 the price of the Honda...
Can be converted to Propane.
Lots of people love em, and have had good service.
I'm running the little HF 2000, and its been stellar so far.
2x 2000s are not enough to supply my Motorhome, sadly.
I am seriously considering 2x 3500s to replace the aging, noisy Kohler 7000.
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 06:20 PM
Honeywell Inverter Generator moosetags Generators & Solar Power 4 11-17-2009 06:40 PM
B190 inverter instead of generator? gingfred Sprinter and B-van Forum 2 11-09-2006 07:10 PM
