08-01-2017, 01:46 PM
#41
2023 30' Flying Cloud
Garden City
, Alabama
If I didn't already own a Honda eu300ie I would give one a try.
08-03-2017, 02:01 PM
#42
2005 28' Safari S/O
Paradise
Predator 3500 vs Honda 2000 Noise
I bit the bullet and purchased a new HF 3500 inverter generator yesterday. I was surprised at how truly quiet it is. I did a very unscientific side by side noise comparison with my old Honda 2000i to give you an idea of what it sounds like and I'm posting the link here. https://youtu.be/GjjxMnbbUvM
My overall impression of the Predator is good and the first couple of hours it has run very smooth, but I am skeptical that it will hold up as well as the Honda has. Some of the parts appear cheaply made as is expected in a Harbor Freight product, but at $650 compared to $2000 for a Honda 3000i, I can buy 3 of these. It's kind of like comparing a Lexus to a Kia.
I can now run my 15,000 BTU AC along with some other things no problem. It does consume more fuel as expected. I used about a half a gallon of fuel running the AC off the 3500 for an hour at about 1700-1800 watts draw. The unit holds 2.6 gallons so I would estimate about 5 hours of run time at about 60% generator capacity. They claim 11 hours at 25%.
Steve
"THE OLDER I GET, THE BETTER I WAS"
08-03-2017, 02:49 PM
#43
Biloxi
, Mississippi
How about repeating the test running one generator at a time.
MICHAEL
08-03-2017, 03:04 PM
#44
Tampa
I think you mean 3000is, but I have one also. I watched Craig's list until I found a nice unit. It looked almost new, ran great, so I bought it. I took the serial number to my Honda power dealer, and they looked it up. "Please tell me it's not a Chinese knockoff." "No, it was originally sold to XXXX in Bradenton, Fl in 2004.
2004? I thought it was 2015 at least.
The Honda guy told me that Busch Gardens uses the same generator, and they consider 200,000 hours to be average life span! I like mine better, still runs flawlessly, but I still watch Craig's list just for good deals.
BTW, if anyone cares, the serial number is below the access door, and you can't search online, but any Honda power dealer can look it up for you.
08-03-2017, 03:36 PM
#45
2005 28' Safari S/O
Paradise
I did this using an Android sound meter app. I tested outdoors at 25 feet measured distance for each genny running by itself. Here are the results in decibels. The top two images are the Honda 2000 with Eco Mode on then off. The second row images show the Predator 3500 Eco Mode on then off. The bottom image shows the location of the generators. A bit more scientific but there could be outside noise influence, although i live in the middle of 3 acres so it's much like a campground
Steve
08-03-2017, 03:46 PM
#46
1995 25' Excella
xxxxx
, xxxxxx
I am impressed and want a HF gen now.
08-03-2017, 08:39 PM
#47
2014 25' FB Flying Cloud
Des Peres
, Missouri
Can it be converted to run on propane ?
08-04-2017, 04:31 PM
#48
1977 31' Excella 500
Zavalla
NOTE TO ANYONE WHO BUYS ONE! CHANGE THE OIL AFTER 8 HOURS (or do it at 4 and 8 hours for good measure!)
The oil comes out filthy dirty after 8 hours and there are specs of metal. Just far more dirty than I expected it to be after 8 hours so you might do two changes if you want to go the extra mile over recommended break in.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
08-04-2017, 04:33 PM
#49
1995 36' Classic 36
Seattle
This is good to know. Would be great if a couple other owners can confirm this is a chronic issue, especially the metal specs.
08-04-2017, 06:07 PM
#50
2000 25' Safari
Davidson County
, NC Highlands County, FL
A few visible metal shavings in the first oil change is normal.
Alan
08-13-2017, 03:22 PM
#51
1965 26' Overlander
1960 28' Ambassador
1975 20' Argosy 20
Upper Black Eddy
, PA
So, in terms of running a roof top RV AC, what LRA is the Predator 3500 capable of handling? The specs indicate a max wattage of 3500. Even a conservative RV AC, such as a Coleman 11,000 BTU, has a start up (LRA) requirement of 41.6 amps which would be just under 5000 watts (amps x 120v equals wattage demand)...although, this draw may only last milliseconds, I can't see how a gennie of 3500 watts could handle that... ????
08-13-2017, 05:41 PM
#52
2000 25' Safari
Davidson County
Alan
08-14-2017, 07:21 AM
#53
Then 2- eu2000i gens wouldn't be able to run a 11k unit either.
LRA is not startup amperage. The impedance of the system will prevent startup amperage from reaching LRA. But even if it did a generator can handle a momentary spike above the peak wattage. Just because it demanded more watts doesn't mean it will produce it. It will simply lag the compressor. But luckily it will only be for a millisecond.
08-23-2017, 02:02 PM
#54
2005 28' Safari S/O
Paradise
I changed the oil at 6 hours for good measure and here is what it looked like. It wasn't bad at all. A few sparkly swirls but about what my the oil in Honda 2000i looked like after it's first oil change. I'm using Valvoline 10W-30 full synthetic. I think I'll change it again in another 6 hours and then after break-in at 25 hours, Then every 100 hours.
Steve
08-24-2017, 08:15 AM
#55
Zavalla
Oil looks great! Mine was black as was another reviewer in a video I watched online. You may have a better than average unit as far as build quality? Or ours are worse than average.
08-30-2017, 03:56 PM
#56
2005 28' Safari S/O
Paradise
These generators are being manufactured under other brand names. Checking the specs on each shows them to be identical except for the price. Here is one made under the Echo brand name... Echo
...and this one is made under the Northern Tool brand... Northern Tool
Steve
08-30-2017, 04:24 PM
#57
2000 25' Safari
Davidson County
Has anyone checked to see if these generators are bonded, neutral to ground?
Alan
08-30-2017, 06:39 PM
#58
2015 28' Flying Cloud
Newtown
, Pennsylvania
I don't think they are, but it's an easy fix.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
08-30-2017, 06:41 PM
#59
Newtown
, Pennsylvania
Echo shows a nice fitted cover for this generator. Can't figure out how to buy one, though.
Bruce
08-31-2017, 05:35 AM
#60
2003 25' Safari
Kissimmee
I'm happy with my single Honda EU2000i running my a/c using the Microair Easy Start. The larger generators are too heavy.
Dan
