Old 07-14-2017, 08:34 AM   #1
Continents Collide
1985 32' Excella
Spring , Texas
New busbar for Inverter
I am going to be installing solar this week on my 1985 excella. I have a 2500w sunforce inverter and I wanted to make sure that my 12v busbar/breaker (I have self resetting breakers) will be able to handle the full amperage of the inverter, should I use all 2500 watts. Does anyone know if the original panel would handle 200-210 amps?
I have a 30amp controller and got 300w of panels but my controller could handle up to 600w. For what that's worth.
I have thought about installing a new 250 amp rated busbar to connect to my charge controller, to the batteries and also to the inverter just in case.
Overkill? Do it?
continentsco is offline   Reply With Quote
Old 07-14-2017, 08:38 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Disclaimer: I have no knowledge of the codes and I am not a professional
But, the only installs I have seen connect the inverter by cables to the batteries, through the appropriate switch and fuse. No bus bars.
Larry
lsbrodsky is offline   Reply With Quote
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Loose Connection at Negative Busbar Al and Missy Batteries, Univolts, Converters & Inverters 1 07-04-2014 03:31 PM
New Inverter for AC power/Help? timkim Batteries, Univolts, Converters & Inverters 11 12-22-2009 09:36 PM
New to Airstream - inverter problems already Badco8 Member Introductions 6 03-24-2007 01:57 PM
Planning new wiring with inverter Jacob D. Electrical - Systems, Generators, Batteries & Solar 8 12-05-2006 09:06 AM
