Originally Posted by Imustwander
This is a factory solar question. I apologize if this has been covered in another thread. I've searched and can't seem to find an answer.
I have factory 90W solar on my 2020 23' GTFBT. I also have a 140W Zamp solar suitcase. If I plug the suitcase into the Zamp solar sidewall port, would the batteries be able to receive charge from both panels? Would I effectively have 230W of solar in a sunny location?
Thanks!
Thanks!
Hi
There is a controller in the suitcase and a separate controller in the trailer. They do not "network" together ( = one does not know the other even exists ).
When the batteries are really dead (like below 12V) this isn't a problem. Both controllers go into full blast mode and even if one gets an occasional spot of shade, all is well. You get the sum of the two.
Once the batteries begin to charge up, you get problems. One or the other "takes over" the entire process. This happens when that spot of shade hits one it comes back and decides the process is done. That one goes into float mode and stays there. Net result is that the second part of your charge process only gets power from one controller. There is no way to know which one "wins" the race ....
Net result is that in the most common case ( = batteries are not way run down ) you only get the output of one controller after they have been on for a bit.
