Old 07-25-2022, 08:26 PM   #1
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Merlin Solar for 2023
https://www.airstream.com/blog/whats...del-year-2023/
Reading this, noticed that Airstream is going to Merlin for solar now.
Anyone have experience with them, versus Zamp, Renogy, etc?
-Leslie
WBCCI #1051
LNBright is offline   Reply With Quote
Old 08-11-2022, 07:37 PM   #2
Air2Dream's Avatar
2023 23' International
Calgary , Alberta
Merlin Solar Package
Airstream’s change to 300 watt solar package is a great change. In addition to the new solar panels, what other changes are included in the change? Airstream no longer provides batteries in the bulk of their units; what lithium batteries makes can be dropped into Airstreams battery box?
Anyone have any experience with this new setup?
Air2Dream is offline   Reply With Quote
Old 08-11-2022, 07:47 PM   #3
2023 28' International
Mercer County , New Jersey
The biggest related change is a multi-stage auto-detecting power converter, which doesn't require any changes for the different battery chemistry options
Details of all the announced changes for 2023 can be found here: https://www.airstream.com/blog/whats...del-year-2023/
jeffb831 is offline   Reply With Quote
Old 08-11-2022, 07:53 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I stopped by the Battle Born booth at the Fryeburg International Rally where they had a drop-in battery for the Airstream battery box. There may be others but that’s one that I know of.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 08-21-2022, 07:14 PM   #5
Air2Dream's Avatar
Calgary , Alberta
Lithium Battery for Merlin
Attached is a Battle Born battery site that has some great information to aid in adding lithium batteries to your Merlin system:
https://battlebornbatteries.com/char...es-the-basics/
Old 08-24-2022, 01:59 PM   #6
Air2Dream's Avatar
Calgary , Alberta
Merlin - How long will it take to charge 200 AH Lithium Battery
The new Merlin 300 watt solar package is a great addition. However is 300 watts enough?
The following website provides a calculator to determine how long it will take to charge a battery. To charge two 100 AH Lithium batteries from being fully expended to fully charged is 9.8 hrs or about 2 days.
https://footprinthero.com/solar-pane...ime-calculator
Old 08-24-2022, 02:13 PM   #7
Air2Dream's Avatar
Calgary , Alberta
Supplementing Merlin
If 9.8 hours to charge your lithium batteries is too long, then sing a portable solar panel is great way to supplement Airstreams 300 watt solar package. Not only can you add additional surface area but th solar panels can be position to maximize collation of solar energy. One simple modifications can further enhance a portable panels output. See the attached video:
Old 08-24-2022, 07:36 PM   #8
2021 22' Caravel
Houston , Texas
I believe the other change in 2023 trailers is the upgrading of the solar pre-wire. 8AWG cabling from roof to controller which should be good enough for 800W of solar on the roof.
In addition the solar port on the A frame can now take 300W so a total of 1100W of solar pre wire.
This is a welcome change as adding this amount of solar previously would typically involve pulling heavier cabling, often with new perforations in the roof.
FredWilma is offline   Reply With Quote
Old 08-24-2022, 08:44 PM   #9
Air2Dream's Avatar
Calgary , Alberta
Great Changes.
The wiring changes are a welcome change. Is there any information available that provides a more comprehensive description of the entire solar setup?
Old 08-24-2022, 08:56 PM   #10
The 8Ga wire is included in the 2022 models and may be even further back than that.
On page 8-16 of my 2022 Int'l owners manual, there is a wiring diagram and it specs the wire from the combiner to the solar control as 8Ga
Old 08-24-2022, 09:04 PM   #11
PlasticThingsHaveNoSoul
2021 33FB Classic
Casa Grande , Arizona
My 2021 Classic owners manual shows 8AWG for solar on page 8-20.
Regards,
Ron
rhensley is offline   Reply With Quote
Old 10-15-2022, 06:27 AM   #12
Claysburg , Pennsylvania
Junction box
At first glance from the ground they look good up there. You might want to check the wiring because it is all just laid around under the panels and mine has already rubbed the white paint off the roof. ( 1 month ). The wire from the panels appears to be much bigger than Zamp. The junction box looks exactly the same as the past couple years.( has a Merlin logo on now) The connections going into it have a hard time staying in
I Airstream support doesn’t know what to say because they are so new. Merlin has yet to answer my message.
We ordered a 2022 with the option and when it finally got built it showed up as a surprise 2023.
Batteries should at least be an option, then A. S. Could stand behind what they sell.
Chipeckhard is offline   Reply With Quote
Old 10-15-2022, 08:22 AM   #13
TrvlngTinTin's Avatar
2022 30' Globetrotter
Erie , Colorado
Got a Great! Surprise this week. Dealer called up and said Hey your Trailers here😀!
Went and took a quick peek.
Surprise it’s a 23. Trailer Looks Fantastic. Maybe one issue with rock guard will see?
But on the solar front I was initially excited to have the extra 30 Watts.
Now 🤔 can’t find these 100 watt panels to add few more.
And yep did not come with the AGMs.
Not sure yet what dealership will offer.
But got my eye on 270 amp hr battery and a 50 amp multi plus.
But supper excited to have airstream 12 months to the day almost.
ID:	424087   Click image for larger version
TrvlngTinTin is offline   Reply With Quote
Old 10-16-2022, 04:21 PM   #14
Erie , Colorado
Are panels 100 watts each? I found These?
Not sure if AS panels are 100 or 150 watts each?
And what specs on back of panel to try and possibly combine?
https://www.custommarineproducts.com...ar-panels.html
Old 10-16-2022, 05:50 PM   #15
2023 23' Flying Cloud
Piedmont area , North Carolina
My 2023 FC has the upgraded solar package - 300 watts. There are 3 panels on the roof so 100 watts each.
Old Dogs-New Tricks
DogMomDeb is offline   Reply With Quote
Old 10-27-2022, 11:56 AM   #16
Lynnwood , Washington
Does your FC come with batteries as well? I heard now you can choose between AGM or Lithium batteries. Is that correct?
scho7623 is offline   Reply With Quote
Old 10-28-2022, 03:31 AM   #17
When we ordered back in 2021, we asked for the AGM batteries to be installed. So for us it didn’t matter that the trailer came without batteries from the factory. They installed those batteries once it hit their lot.
Eventually we want to covert the queen to twins and upgrade to the lithium batteries.
I don’t know if there would have been a problem if we had changed our minds, (once the trailer was complete) and wanted the lithiums. Certainly it would have cost us more but I assume that they could have put them instead.
Old Dogs-New Tricks
Old 02-08-2023, 06:46 AM   #18
2023 27' Globetrotter
Winder , Georgia
Has anyone that has received a new trailer with the Merlin solar package received any literature whatsoever with your owners manual kit?
My kit seemed to missing this as well as other manuals for key components?
No info whatsoever on the panels , or the control panel inside the trailer
Bcc75 is offline   Reply With Quote
Old 02-09-2023, 05:43 AM   #19
I do not remember seeing any literature for the panels. They are 100 W each.
Could not find much information on them at all.
As far as the controller, it is all Victron, and is very easily found on the Internet. I do remember seeing a very small pamphlet. ( fyi it is NOT Bluetooth)
Old 02-09-2023, 05:58 AM   #20
2016 16' Sport
Miami , Florida
I don't know what Victron controller they install now but if it has a VE direct port then its easy to just plug a Bluetooth dongle into it.
Shiny16 is offline   Reply With Quote
2023 Basecamp 20x Solar Question ErickfromMI Base Camp 9 07-31-2022 04:32 AM
Ordered a 2023 FC 25FB- wont arrive until spring 2023 waninae39 2016 - Current Flying Cloud 48 07-17-2022 05:39 AM
2023 International Location?? Gkiesel WBCCI Rallies & Events 10 07-09-2022 07:40 AM
No Solar Option on 2023 Globetrotters? jondrew55 2018 - Current Globetrotter 14 01-25-2022 11:04 AM
Looking for Merlin pamu General Repair Forum 6 03-03-2016 08:25 PM
