Originally Posted by Msowers22
So on my 2019, I’ll I really need to change is the solar controller and drop the lithiums in?
As Lewster said in post 2, you'll probably want to replace the AC-to-DC converter to maximize the charging capabilities of the lithium batteries. Airstream didn't start adding converters with the lithium switch until sometime in the 2021 model year.
Depending on the solar controller you have, there may be a switch to select the type of batteries that are being charged (Victon one's do). If there is not one, you may also want to replace the solar controller to maximize the charging capabilities of the lithium batteries.
