11-07-2018, 02:38 PM
2016 19' Flying Cloud
Clearwater
Just installed custom generator rack on Bambi
11-07-2018, 03:45 PM
2007 27' International CCD FB
San Diego
Looks like it's solidly built.
Is there a particular reason you're opting to carry 2x gennies? I would think a Bambi has the smaller 13.5k A/C which could be handled by a single genny with easystart?
11-07-2018, 04:11 PM
2012 Avenue Coach
Corpus Christi
Originally Posted by Mwgautreau
. . I worked with a local metal fabricator to build an aluminum rack to bolt over the battery box. It uses the “puck lock and plate” configuration on either end to secure the generators (also made of aluminum) and we put a mount in the middle to secure a crush proof Jerry-can to carry fuel.
Welcome to the forum Mwgautreau!
Well designed and executed. But what about rain and weather protection?
11-07-2018, 06:15 PM
2019 25' Flying Cloud
Hendersonville
, North Carolina
Custom Gen Rack
How much does all of that weigh including full Fuel Container?
11-08-2018, 02:39 AM
Clearwater
Airstream dealer recommended the two small generators for boondocking the 19 Bambi Flying Cloud. I’ve read posts from people who have been successful with just one. Each generator weighs 47 pounds. I haven’t put the rack on a scale yet but it’s aluminum and is lighter than a generator. A gallon of gas weighs about 6 pounds. I can carry 5 in the can. I purchased the covers in the picture below for weather/travel protection.
11-08-2018, 04:24 AM
Chelsea
, Maine
That’s very cool! If I didn’t have a front bedroom and the associated front storage door I would do something similar.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
11-08-2018, 04:34 AM
Mantua
, Ohio
Are you going to remove them for operation?.
11-08-2018, 06:23 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
After seeing several different strategies for carrying small Honda generators on an airstream, I worked with a local metal fabricator to build an aluminum rack to bolt over the battery box. It uses the “puck lock and plate” configuration on either end to secure the generators (also made of aluminum) and we put a mount in the middle to secure a crush proof Jerry-can to carry fuel. The center plate on the rack is removable so you can access the batter department without removing the rack. However, removing the batteries would likely require unbolting the rack. I can still use the anti-sway hitch and can still access the spare tire rack underneath the trailer.
Attachment 327298
Attachment 327299
Attachment 327300
Welcome to the Forum,
This is what the 23D Club would call a quality item. Well Done! This looks like it will meet your needs well.
Looks like it is built very well.
180lbs of tongue weigh is nothing to sneeze at but well within a manageable limit. (better than 180lbs on the rear)”my opinion“
Keep us posted on how it’s working out.
Also if you have any more detailed pics that would be nice. I always enjoy studying others design work.
11-08-2018, 06:50 AM
Clearwater
The rack is designed to run the generators in place. The exhaust faces outward while the controls and ports for linking the generators face inward. Here are some more “technical” pictures;
11-08-2018, 08:29 AM
2016 26' Flying Cloud
Southlake
Looks nice. It looks like two guys could remove the nuts from the u-bolts and haul the whole thing off. I would somehow secure those nuts.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
11-08-2018, 09:19 AM
Overkill Specialist
Dadeville
, Alabama
Maybe turn the U-bolts over and drill some holes through the top to access the nuts. The holes to remove the nuts would be under the generator when locked in place and would not have access. You would also need to weld a “guard” in place to prevent accessing the outside bolts from the underside.
Just an idea?
11-08-2018, 10:08 AM
2013 25' FB Flying Cloud
2017 28' Tommy Bahama
Penticton
, British Columbia
Just Installed Custom Generator Rack On Bambi
Nicely Done!
Did you/fabricator make sketches with dimensions that you/they maybe willing to share?
Tx's
11-08-2018, 10:14 AM
2016 30' International
Quartz Hill
Have you tried running them in place yet. I wonder about the vibration transferring to the frame and felt inside the trailer specifically the floor.
Great installation though. A good idea if you have limited space available in ones tow vehicle.
11-08-2018, 10:19 AM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
There is one issue that I see, clearance during tight turning.
Please check
"Chip Tank" is in Westwood Ca.
11-08-2018, 10:22 AM
Charleston
, South Carolina
Two running slow is better than one running fast. I just spent a night on generator power last week in my Interstate, but I put my Yamaha generators in front of the van on the ground with a 50 foot cord. I pointed the exhaust downwind and put in some earplugs. I also have a secondary sensor in the van for safety. They ran for 10 hours on one tank.
11-08-2018, 10:26 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
And when they are not running and on the pad...are they protected?
The solution is a bit overkill for us, but with limited TV & AS storage the tongue rack may work well for you.
Sweet streams...
11-08-2018, 10:40 AM
S/O#080
2006 30' Classic S/O
Naples
Nicely done. On a recent caravan we saw something similar with an added aluminum cover. Looked nice.
11-08-2018, 11:15 AM
2013 25' Flying Cloud
Wheaton
If only to equalize the load, albeit, an expensive way to do so.
Greg
11-08-2018, 11:39 AM
Wasilla
, Alaska
Nice work. Looks great and should do the job .
11-08-2018, 12:03 PM
2017 20' Flying Cloud
Appleton
, Wisconsin
I've been trying to figure out how and where to stow a Honda generator. This could be the best solution. I, and from what I read - others would love to have the specs on this if possible. Please advise. I also liked the idea of putting an alumn. cover over it, like the propane tanks have so I can secure it that way.
