RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-13-2021, 12:31 PM   #1
2015 Interstate Ext. Coach
Santa Barbara , CA
Is solar working?
2015 interstate solar, display shows battery voltage at 75%, 12.3 volts, .1 amps and 8.4 hours (after zeroing it 3 days ago).
I have read the solar should kick in when the battery drops below 12.4 volts.
Does the battery disconnect need to be on to get accurate info? Seems counter intuitive to do that, to me anyway.
This was Interstate purchased used and not all the printed info was provided , so I’m guessing at some systems.
Any help or suggestions welcome!!
calmal is offline   Reply With Quote
Old 01-13-2021, 02:31 PM   #2
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
The 200w panels charge whenever the sun shine - the controller show "Green" at 13.4v which is float charge and will show "yellow" charging when it drops. Basically maintains the state of charge. So I can only assume that's the way it should work - at lease it does for us.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-13-2021, 08:18 PM   #3
Santa Barbara , CA
Thanks for the response dbrick.
I am looking at the display in the upper cabinet with the other displays and generator starter.
I have looked for the controller, no go so far.
I think it’s under the rear lounge bench seat.
Now trying to figure out to the seat off to get under it. There is what looks like an access panel, but it won’t come out due to equipment attached to it inside... thus removal of the seat bottom removal .
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 12:25 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
My solar not working Beach Bum Generators & Solar Power 10 03-29-2016 04:51 PM
Is my solar panel working? And other electrical problems. as77 Generators & Solar Power 7 09-23-2014 04:15 PM
Solar panel, is it working? mgap Generators & Solar Power 7 05-17-2013 01:25 PM
