Update on solar install
Just wanted to update this thread in case anyone was curious. I took the advice of uncle_bob and a couple others I pm'd.
In the end, removing the trailer interior in that area was not difficult. First removed the table then after about 9 screws (3 of which were into the aluminum sides of the trailer, the others into the adjacent cabinet), I was able to lift the wood structure up without damaging the heating duct. That gave me nice access to the DC power distribution box.
Once there, was able to wire the +/- connections to the bus no problems. Also, I found that the green/yellow connections were, as they should be, connected to the 3 port connector box on top of the trailer. Those three connectors are connected in parallel and in spite of what others said, don't seem to be connected backwards. But I definitely buzzed them out to be sure. Used green for ground and yellow for positive. I have installed a pair of 100watt flexible panels on the roof and a low cost PWM controller near the DC distribution box. Depending on how much I use the solar, I may add more panels and a more elaborate charge controller. Ping me if you have more questions.
