Old 07-30-2018, 12:21 PM   #1
framingham , Massachusetts
How often do you run your Honda EU7000?
I have a generator for the rare (once every year or two) power outage. So I periodically run my generator. I used to run my EB2200 3-4x/year and that was sufficient, but the dealer says I need to run my new EU7000 every 30 days - true? How often do you run yours? Thanks!
jeffw_00 is offline   Reply With Quote
Old 07-30-2018, 01:52 PM   #2
Mollysdad's Avatar
First, knowing I might not be conscientious, I'd find ethanol free gas.
Around me, Wa-Wa has it.
Then I'd be sure to add Sta-bil.
If you go a few months without starting (I have) it still fires right up.
Old 07-30-2018, 06:59 PM   #3
The sales guy at my dealer pushed the ethanol-free gas (~$25/gal). My approach had been to use Marine Sta-Bil when I buy my (regular) gas, keep the tank topped off, and don't keep gas more than a year.
I asked two different tech support guys at Honda on different days, as well as another sales guy at my dealer, which approach was better. The other sales guy said my approach was "fine". The Honda techs specifically said thet recommend my approach, and they do not recommend ethanol-free gas. They didn't say it would hurt, but they don't recommend it.
Just sayin'
/j
I'm leaning toward starting it up every 90 days, but wondering how that works for others
Old 08-02-2018, 05:15 PM   #4
anyone?
Thanks!
Old 08-02-2018, 06:01 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I have a 5000 and run it every couple of months. Mostly to keep the starter battery charged. I use Stabil too
2019 Ford Expedition Platinum
Old 08-04-2018, 07:14 AM   #6
Actually - lead-acid batteries generally hold their charge a really long time. I keep debating whether to go every 3 months (like I used to) or up it to 2 because the new Honda needs it more often than the old one (?)
/j
Old 08-04-2018, 07:28 AM   #7
Wayne&Sam's Avatar
Images: 21
The batteries do, but I do not. If I don’t try to do it that often, it will go too long....
Old 08-04-2018, 07:39 AM   #8
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The weak link is the fuel in the system. Run it dry / drain it / blow it out (maybe). It'll store a long time if it's completely dry when it goes into storage .... ( yes, put new oil in it when it comes out after a long time sitting ...).
Old 08-04-2018, 01:25 PM   #9
Actually - since the EU7000 is fuel injected - there's no gas shutoff and no need to shut it off and then run it dry (as per Honda)
Old 08-04-2018, 02:16 PM   #10
Mollysdad's Avatar
Yikes!
The Wa-Wa near me has a E free pump and it's expensive at $3.09 last time I checked. (but 89 octane since it's not diluted with corn squeezins'.)
Old 08-04-2018, 03:01 PM   #11
Yeah - apparently it's cheap in southern climates where it has more utility, and hard to find in the northeast
Old 08-04-2018, 03:08 PM   #12
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
Originally Posted by Mollysdad View Post
Yikes!
You may be surprised to learn that ethanol has a very high octane rating (114) and is not used to dilute the octane of gasoline, but to improve it.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 08-04-2018, 05:15 PM   #13
r carl's Avatar
Lin , Ne
I choose not to support the corn cartel.
Old 08-05-2018, 06:24 AM   #14
Lakes Region , New Hampshire
MAYBE once a year, so far, if I need it.
Okay, I converted it to propane, I've wrecked too many things with bad gas...
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
RandyNH is offline   Reply With Quote
Old 08-05-2018, 08:13 AM   #15
Mollysdad's Avatar
Yes, I'd be bowled over if ethanol treated gas had more energy than regular gas.
It's no secret that a given vehicle will get worse fuel mileage on ethanol, and have less power.
Ethanol is all about the $$$$ and not about efficiency.
Old 08-05-2018, 09:00 AM   #16
You are confusing energy in the fuel with octane. "Octane ratings are measures of fuel stability. These ratings are based on the pressure at which a fuel will spontaneously combust (auto-ignite) in a testing engine."
The energy in the fuel is a different thing and does not correlate to octane rating. "A gallon of E10 has 96.7 percent of the energy in one gallon of gasoline, according to the DOE's Alternative Fuels Data Center."
Ray B.
Old 08-06-2018, 08:08 AM   #17
Half a Rivet Short
2022 Interstate 24X
Hi
.... and a gallon of E85 is even worse in terms of energy density at 76%. Remember that when you are tempted to fill your tank with the lowest price fuel at the pump .... If full up regular gas is at $2.50 a gallon, E86 needs to be below $1.87 a gallon
Honda EU7000 TavnAsh Generators & Solar Power 62 05-03-2021 01:36 PM
How often do you use your shower | Poll Janet H General Repair Forum 96 02-13-2016 07:18 AM
How often do you check your tire pressure? Fam-Bambi Towing, Tow Vehicles & Hitches 37 07-31-2012 08:28 AM
How often do you use your genny? gowyn Generators & Solar Power 26 02-13-2008 07:25 AM
How often do you use your Airstream? kamadeca On The Road... 7 03-25-2003 07:21 PM
