Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 02-13-2011, 05:59 AM   #1
glasgow , maryland
Honda gen 2500H-Wont Idle Under Load
The output of my generator wasn't sufficient at the factory idle setting to supply enough voltage to my battery chargers to create anymore than 13.5 volts to my batteries. When adjusted the idle i was able to increase the output voltage and thereby increase the charge voltage to my batteries to 14.2
Now when i put a load on the generator, vacum cleaner, the generator idle fluctuates up and down until the load is removed.
I need to maintain the higher idle speed but did I adjust that in the right place?
Can anyone tell me how to make this adjustment please?
marion macdo is offline   Reply With Quote
Old 02-13-2011, 07:11 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
What is the exact model of your generator and how old is it?
Michelle TAC MT-0
Sarah, Snowball
thecatsandi is offline   Reply With Quote
Old 02-13-2011, 08:21 AM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
IF your genset is not out of warranty and even if it is. Id suggest you take it to the nearest service center for that brand and have it adjusted by a HONDA TECH. They may not even charge ya nothing. IF they will not do anything Call CUSTOMER SERVICE.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
honda 2500h, idle speed adjustment
