Old 10-28-2019, 02:39 PM   #1
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Honda EU2000i Propane/Cold Weather operation
I have a Honda eu2000i converted to Genconnex propane. Has worked fine, but last night I was helping out some friends who are out of town, by winterizing their trailer at their storage unit, as temps are headed to single digits. They would have experienced some expensive damage for sure, starting with their water heater...they owe me big time :-)
I took my compressor and generator and a full 20# propane tank. Could only get the genny to 'burp' a couple times...would not start. I heated a pot of water and poured it on the regulator...was able to get it going finally.
I shut it off for a few minutes, while I had a fully pressurized compressor, and did my first blowing off all the fixtures and low points. Then when trying to restart the generator again after pulling the 'primer' knob to flow propane...no joy. It would run (no load from compressor) for 3-4 seconds, then die. It actually sounded like I was experiencing the bad spark plug cap problem outlined in this thread:
http://www.airforums.com/forums/f448...ps-172577.html. But my Serial Number is EACT-1606773 which is well before the numbers that had the problem (they started at 162xxxx).
Has anyone experienced problems getting their propane-fired Hondas to fire up in 20sh degree temps? I'm wondering if heating the regulator with water got it going the first time, but then exacerbated the problem when I turned it off and let it cool for 10 minutes...and freeze up even worse, restricting propane flow?
My concern is that with solar I have not needed the generator, but with any winter camping and protracted furnace use, my luck will run out...and I don't want to discover a problem with the genny when it's 15 degrees and I'm out in the field.
pcskier is offline   Reply With Quote
Old 10-28-2019, 04:46 PM   #2
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Sold my Honda 2000 with propane conversion for same issues in cold temps. It would start fine on gas, but temperamental on propane. Got the Champion 3400 with dual fuel and electric start which works fine.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 10-28-2019, 05:22 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Peter,
This is what I found. May have been because your tank was full and the propane would not gas off with so little space and the cold temps. How cold was it?
Old 10-28-2019, 06:24 PM   #4
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Originally Posted by GMFL View Post
Peter,
Thanks Ronnie.
It was higher than 20 degrees and the tank was full. Could be something to this theory, as when I poured hot water on the regulator, I also poured some on the tank, warming up the OBD valve and tank itself. Then it started and ran fine. It was after I shut it off and it all cooled that it wouldn't run again.
What I left off my post is I then cranked the heat in the truck and put the tank (hooked to the hose) on the floorboard and let it sit in there for 5 or 10 minutes or so till it all warmed up...with generator outside the truck (but tank inside with door open a little for hose exit) the generator started again.
I think in future if winter camping I'll heat the tank and hose/regulator in the truck for 10 minutes or if I have any problems with starting. Once it was running, it was fine. The restarts after it all cooled down for awhile were the problem. Genconnex also says to try pointing the exhaust at the propane tank to warm it up with that as well.
Good news is that this will be a rare need, I don't winter camp much without electrical hookups, if at all.
Old 10-28-2019, 07:22 PM   #5
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
I just got back from camping in cold temperatures (20’s) and high elevation (up to 9,000 feet) and I had trouble with mine as well. I could usually get it started on the 3rd or 4th pull, but it would normally die after about 10 seconds. After several attempts it would normally stay running. My tank was only about 3/4 full.
When I got home (elevation 400’ and temps in 50’s), I put in a new spark plug and it still took 3 pulls to get it to start, so it was not the plug.
billrector is offline   Reply With Quote
Old 10-28-2019, 10:46 PM   #6
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Interesting Bill thanks for the feedback. The fact that it runs ok once it gets going is interesting—so it’s not necessarily a propane tank/regulator issue. Especially at 9000 feet is another factor. Did you have the high elevation orifice installed?
Also note that Genconnex recommends using a Champion Z9Y plug with a gap of .020-.022 inch. I have not changed mine but plan to.
Peter
Instagram: @thealuminumtent
Old 10-29-2019, 04:18 AM   #7
2017 FC 28 Twin
Plymouth , Indiana
Have 2 Genconnex Honda’s 3000 & 2200 Genconnex ships with a Black or low flow end which hooks to the propane tank switch to a red high flow problem solved
2017 FC 28 w/ Shocker hitch
2014 RAM 3500 4x4 mega cab drw
Dragline is offline   Reply With Quote
Old 10-29-2019, 05:31 AM   #8
2016 16' Sport
Miami , Florida
Time to eat children.
Shiny16 is offline   Reply With Quote
Old 10-29-2019, 05:40 AM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Genconnex show Red regulator pressure “Too High”
Old 10-29-2019, 05:47 AM   #10
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Genconnex now recommends NGK CR5HSB 0.020-0.022”
Of course I went with the NGK CR5HIX iridium plug. Smoother and Hotter.
But I think your problem was related to fuel not spark.
https://www.ngk.com/product.aspx?zpid=41404
Old 10-29-2019, 05:49 AM   #11
Silvr_Bullet's Avatar
2017 16' Sport
Woodstock , New York
Could be a problem with the propane supply line.
Silvr_Bullet is offline   Reply With Quote
Old 10-29-2019, 06:42 AM   #12
billrector's Avatar
Fort Worth , Texas
Interesting question! I used the generator sparingly in Moab so I did not worry about it. When I got to the North Rim and it had problems, I installed the high elevation orifice. I thought that would be the answer, but honestly it did not see much if any difference.
Old 10-29-2019, 07:10 AM   #13
billrector's Avatar
Fort Worth , Texas
And.....I replaced a NGK spark plug with a Champion and see no difference. Both were gapped to 0.02
Old 10-29-2019, 10:37 AM   #14
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Regardless of the appliance, cold is never a great thing for propane. Pressure in the bottle drops with temperature. As you use gas, the liquid boils and that cools the bottle down, pressure then drops even more. Depending on just what the regulator needs for a minimum input pressure, you get trouble at some point. Tossing the propane bottle in the blazing campfire is *not* a recommended solution
Is bottle pressure what's going on here? Not at all clear, just a possibility. At roughly 20F the tank pressure should be around 35 to 40 PSI. It would drop to about 25 PSI at 0F
Old 10-29-2019, 11:58 AM   #15
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Does your Honda generator have the "Cold Climate Technology" option? (see photo- it's the only model they sell in our cold corner of the continent).
It essentially uses an electric heating element to keep the air intake sufficiently warm so that the carburetor won't freeze up.
However I don't know if it would help with the starting up of the unit (I have a Hutch Mountain propane converter and have not experienced cold weather starting problems).
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 10-29-2019, 12:53 PM   #16
billrector's Avatar
Fort Worth , Texas
Nope...never heard of it!
Old 10-29-2019, 08:03 PM   #17
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
honda breather heater see pdf
Found this on the Honda site FWIW
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2018 RAM 1500
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 10-29-2019, 10:17 PM   #18
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Somebody touched on the problem. It is the low rate of propane boil off due to low temperatures that causes low or no fuel flow . There are several easy solutions: use a: "L" Port 3-way valve connected to both propane bottles with a "Wye" on each tank. When the temp gets too low go to an intermediate position on the valve so as to feed off both tanks simultainiously. Caution: if you use an "T" Port valve the intermediate position will defeat your automatic change over shuttle valve and cause you to loose propane service to the trailer, think heater. One of our WBAC units boondock rallies in the winter and they have used insulated heated tank blankets and or exhaust to add heat to the tanks. All this is a chicken and egg problem. You really need to start off with warm bottles in order to stay ahead of the game. In other words start warming the tanks before the temp can shut you down. The best place to test this is in your driveway. Thats how I discovered the T/L Port problem. I had to do an emergency winterization to save the plumbing.
guskmg
Old 10-30-2019, 04:10 AM   #19
2017 FC 28 Twin
Plymouth , Indiana
[QUOTE=GMFL;2302767]Genconnex show Red regulator pressure “Too High”[/QUOTE
Well let’s see been hauling working repairing in the propane industry over 15 years been using my Honda 3000 for 7 years now my 2200 since released not only for the AS but as backup power for the house neighbors whomever plus during winter spring summer fall temps, so yea listen to what the lawyers say on the paper,change plugs, warm up tank in the truck, & whatever.
Honda EU2000I Generator and EU2000I Companion Mldun Airstream Classifieds 0 03-29-2018 10:51 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
GenConneX Propane Conversion for Honda EU2000i Airrogant Generators & Solar Power 56 08-26-2016 08:36 AM
Dual propane tap for 2 Honda EU2000i generators fred bartlet LP Gas, Piping, Tanks & Regulators 2 05-09-2010 12:31 PM
