12-27-2020, 06:30 AM
2023 27' Globetrotter
Winder
, Georgia
Honda 2200i with propane
I am considering buying a 2200i for our new trailer. I have a 25’ Int. with one AC.
I plan to install the soft start on the AC unit for the generator. What I am debating is whether or not to get the propane conversion.
Will this allow the generator to be used with the low pressure LP port on the front of the trailer? That seems like a huge convenience although you are sucking propane from your onboard tanks. We have the on demand water heater so adequate propane will always be a concern. We could always carry the smaller bottles in the truck but that’s just more weight, etc.
also for those who have the propane conversion, did you install yourself or buy the generator already converted?
Thoughts?
12-27-2020, 06:56 AM
2012 25' FB International
Trent Woods
, North Carolina
A lot of threads on this subject if you search, I bought mine from GenConnEx, already converted. Nice clean install. Yes you can use the connection on the front of your trailer. One guy here reported that he could actually run two in parallel off that tap, with a bigger hose. I have a composite tank that I carry with me for boondocking if I think I am going to need to run two generators...not very often. As little as I actually use my generators, I would never put gas in them. Propane is the way to go.
Larry
12-27-2020, 08:31 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I converted our 2000i in 2006 with a dual fuel kit from UScarb...SFSG.🤓
12-27-2020, 08:38 AM
2021 33FB Classic
2019 30' Flying Cloud
Katy
I purchased Honda eu2200i and eu2200ic companion generators. I bought tr-fuel conversion kits from Hutch Mountain. It took less than an hour total to install the conversion kits in both generators. I purchased 2 MicroAir Easy Start devices (also from Hutch Mountain, who offers a free and better installation kit than MicroAir does). Hutch Mountain also sold me all the tubing and fittings required to hook everything up.
On several occasions, while boondocking in the heat of summer in South Texas, I have been able to run both AC units all night long (as well as other electrical devices in the coach) while plugged into the propane port on the front of the trailer.
The answer to your inquiry is "yes".
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
12-27-2020, 09:29 AM
Star
, Idaho
You may want to consider a dual fuel generator. Firman makes a nice duel fuel 3300 watt, 58d, weight 98 lb, less than $1000. Allows you to switch fuels while running.
12-27-2020, 09:57 AM
Pbfec
2019 25' Flying Cloud
jupiter
Propane conversion
Thoughts?
Definitely convert to propane and will no longer have to haul gas. Buy the kits from Hutch Mountain.
https://www.hutchmountain.com/
12-27-2020, 10:08 AM
2016 23' International
Los Altos
honda Lp
we have the Honda 2200i with propane conversion. had Genconnex do it. We use the LP quick release port and a double hose so generator is set back from camper.. just to charge batteries.. works great but will suck down about half a bottle of LP running gen. for 4 hours over a weekend..
also have the easy start installed on our AC. was not able to keep compressor running more than 5 minutes in October in california dessert before it shut off. that was disappointing..In colder weather, running AC off gen works fine, but why run AC in colder weather?
12-27-2020, 10:14 AM
2020 25' Flying Cloud
lake Wales
I have exactly your set up. I run my AC off of the generator with soft start. I have a Rubber Made container it fits in perfectly along with a bike cable lock. This way I can carry in the back of my suv. As far as propane consumption, with my 2 Stock 30lb tanks, not sure how long it will last, but my guess is a month. Very stingy of fuel. When I am boon docking, I run the generator for about 2 hours and charge my batteries for all night power.
12-27-2020, 11:06 AM
North Las Vegas
, Nevada
I purchased the Champion 3400, and it is dual fuel set up from the start. I have never used gas in mine only propane, I prefer propane over gas.
The unit was cheaper than getting two Hondas 2000, which is what i would have needed to run the A/C. I am very pleased with the performance and noise level of the Champion.
Dave Gilbert
Foiled / 20' Flying Cloud (2019)
12-27-2020, 11:23 AM
2014 25' FB Eddie Bauer
Vero Beach
FWIW, I have run two Honda 2000s on propane from my LP port with stove, water heater and fridge also running full blast on propane (I did a test to see what happens... it works).
This significantly exceeds the rated 25,000 BTU of the low pressure port and is therefore not supported by Airstream!
Why does this work, and why would I (a risk-averse, conservative guy by nature) do this?
Well... propane system performance is affected by ambient temperature... the warmer the air, the faster the propane in the tanks can convert from liquid to vapor. The only time I might need both generators is to run AC. In other words, when it’s seriously hot and the propane system is at its max performance.
I have not explored the other end of the curve (e.g.: below 32 degrees ambient). I would expect problems... perhaps serious problems... at some point as the draw from devices exceeded to ability of the propane system to meet the load.
So, on a hot day, I will run two Honda 2000s. I don’t run the water heater or stove concurrently. I feel comfortable with that.
12-27-2020, 11:45 AM
2019 27' Globetrotter
Litchfield Park
Larry
We also bought ours from GenConnex. Use the port at the front. Appreciate not having to carry gasoline around. Don't have to worry about gas in the generator going bad when the generator is not used for a long time and some gas sits in the tank. Much cleaner operation. Less stinky exhaust. Agree with Larry, propane is the way to go.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
12-27-2020, 12:18 PM
2004 30' Classic Slideout
Fenton
, Missouri
I bought a tri-fuel Yamaha 2000is from US Carbonation a few years back. My purpose was for back up power at home and on the road for my wife's dialysis equipment. Although it did have enough capacity to keep my Classic powered with the fridge and water heater running on propane. However it would not run my air conditioning. My vintage trailer does not have the low pressure outlet. My plan if needed was to run it off one of the 30 gal tanks on the trailer if necessary. I also bought 2 20 lb tanks to carry if I wanted extra capacity.
I've attached a picture of it running on gasoline as I was breaking it in.
As it ended up I never had to use it at a campground but I did have to use it at home twice for power failures in the middle of the night (when her dialysis equipment was running). I did have to break the unit in under load with one tank of gasoline, but after that point I never have had gasoline in it since. Propane is much cleaner burning and of course doesn't degrade like gasoline does.
I noted that it is tri-fueled and I can also run it on natural gas. I have a gas outlet on my deck that I use for the BBQ grill. I have a hose that snaps into the connection point of the grill and connects to the generator. I would use that if I had a long term outage to provide occasional power to the refrigerator and other appliances as necessary.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
12-27-2020, 12:32 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
MacGyver can do that...shut the petrol valve and un-pinch the LP supply line when it starts to stumble.😂
12-28-2020, 08:46 AM
2018 27' Globetrotter
2013 25' FB Flying Cloud
Glade Park
Your hypothesis on cold weather with propane is spot-on (in our experience)! We have the Hutch Mountain conversion kit and it has worked well feeding our Honda eu3000is - until the temps dipped below freezing. Unfortunately, have to use gasoline in freezing temps - which is most of the time currently in Colorado.
01-03-2021, 04:51 PM
2009 25' FB International
Tavares
So why did the compressor (assuming the A/C compressor) only run for 5 minutes before shutting down. Was the Honda 2200i not able to provide enough power?
