RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-07-2016, 08:17 PM   #1
RxGuy's Avatar
2010 27' FB International
Bois Blanc Island , Michigan
Harbor Freight Predator 2000 Inverter..Anybody try one?
Saw these online, not really in need of a generator at this time. Was wondering if anybody had tried one of them.
http://www.harborfreight.com/engines...arb-62523.html
$499.00 less 20% off, you could buy one for $399.00
I know it's HF.....
RxGuy is offline   Reply With Quote
Old 12-07-2016, 09:14 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Loud!
MICHAEL
Old 12-07-2016, 09:23 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I have heard them. Not that loud compared to an open frame generator.
CRH is offline   Reply With Quote
Old 12-08-2016, 08:36 AM   #4
RxGuy's Avatar
66 dB vs 59dB for a Honda, After looking up the dB scale, the difference is huge....
Thanks....
Old 12-08-2016, 08:51 AM   #5
Bauxter's Avatar
Columbus , Ohio
Champion
Champion has lower db's than HF. It is a little more expensive than HF, but cheaper than Honda. I think a good compromise.
Mke
Bauxter is offline   Reply With Quote
Old 12-08-2016, 08:51 AM   #6
FCStreamer's Avatar
2014 30' Flying Cloud
I'd rather do a Champion. Only a little more $$$
http://www.campingworld.com/shopping...with-usb/70828
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 12-08-2016, 10:14 AM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Thanks....
While 7 dB is a lot in noise power (over 4x) the human ear has a non-linear sensitivity; the ear's response curve is that 10 dB sounds twice as loud. So the HF unit is louder than the Honda, but would not be perceived as twice as loud.
Another thing to check - at what output level and distance were the measurements taken? I think I recall that some generators are specified at full load, others are not. I'm not sure I have seen the distance specified; double the distance, subtract 6 dB.
Just information.....YMMV
Al
Old 12-08-2016, 12:43 PM   #8
1964 24' Tradewind
Enumclaw , Washington
Harbor freight inverters
I sell inverters to rental stores. I will tell you that you will not get much for $499.
Wholesale inverters cost that much or more. If you need clean power, you will need an inverter NOT a typical generator. It doesn't take much for unstable power to mess up your electronics.
Our '64 has NO electronics in it so we don't care--we do have one for CPAP machines--it is not worth saving $$ if I mess up one of these at $1500 each.
Honda, or one of the other main brands will provide years of useful service. if you can find a Mi-T-M inverter from a rental store or construction supply store that is a good unit for a reasonable price. They also have excellent customer service.
Just my two cents.
wolffullmoon is offline   Reply With Quote
Old 12-08-2016, 01:36 PM   #9
interstateflyer's Avatar
2017 25' International
Los Osos , California
I give the density of the generator's exhaust as much consideration as the decibel rating.
Nothing worse than camping next to someone with a smelly generator. I'd like to think that I'm a good neighbor and I strive to use generators that have low dBs and clean exhaust.
Knowing what I know of Harbor Freight products, I doubt that they'd meet my good neighbor standards. Also, a $500 inverter generator is just that.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 12-08-2016, 01:49 PM   #10
Fbastian's Avatar
2017 23' International
Danville , Pennsylvania
Amen to interstateflyer's reply
Fbastian is offline   Reply With Quote
Old 12-08-2016, 02:33 PM   #11
AWCHIEF's Avatar
Images: 33
Ditto, that is one of the reasons I converted my Yamaha 2000 to a tri fuel propane conversion. Quiet and clean burning. Plus no residual gasoline smells in storage.
MICHAEL
Old 12-08-2016, 04:17 PM   #12
1996 25' Excella
Tillsonburg , Ontario
Quote> Al and Missy " I'm not sure I have seen the distance specified; double the distance, subtract 6 dB."
That is correct. Decibels are probably quoted at 3 feet on the machine so at 6 feet the perceived noise level is about 6 dB less and at 12 another 6 dB which is "huge". Still a cheap unit has a poor muffler and the noise spectrum will be much more annoying than the rumble from a well muffled source The staccato pop from a cheap muffler sounds louder than a rumble even if the dBs are equal.
JCW
JCWDCW is offline   Reply With Quote
Old 12-08-2016, 06:14 PM   #13
CRH
1995 25' Excella
xxxxx , xxxxxx
Most generator noise seems comes from everything but the exhaust.. Hold a wet rag over your exhaust and see how much it muffles or actually doesn't.
Old 12-08-2016, 06:30 PM   #14
RxGuy's Avatar
The good neighbor thing is very important. We always try to be considerate campers. Using the guideline of: "Treat people like you would want to be treated." Using a noisy/stinky generator definitely would be a problem.
Old 12-09-2016, 08:56 AM   #15
Box Elder (formerly of Center Moriches, NY) , South Dakota
Something I NEVER see listed is the DUTY CYCLE of engines. I expect that Honda and Yamaha will have substantially longer duty cycles than the bargain brands. I expect that's why both Honda and Yamaha units can be worked hard on a regular basis and still be viable a decade plus later. Duty Cycle is the reason an HDT (Heavy Duty Truck) or even an MDT (Medium Duty Truck) will far outlast any pickup truck.
NY24 is offline   Reply With Quote
Old 12-09-2016, 09:58 AM   #16
2005 28' Safari
Saint Joseph , Michigan
fine print..
devil in the fine print, coupon does not cover generators, or Predator brand.. know 'cause I had one in my cart and was refused.. ok, because I got a bigger, better flash deal on Black Friday..
I know it's HF.....
TruckerFritz is offline   Reply With Quote
Old 12-09-2016, 11:20 AM   #17
2008 23' Safari FB SE
Freeport , Maine
I have one and have used it occasionally on a few trips. The noise is not so objectionable. Problem I HAD is: when new it started on first pull (follow the starting directions). After a year or so, it was hard to start, many pulls. Solution: use K100 additive to gas which is available at some NAPA stores. This helps to fire old gas.
Even with the K100 I have a practice of turning off the fuel supply while generator is running to clear the carb from any potential accumulation of muck from ethanol gas. I think this helps some.
I now use an inverter attached to my truck battery which supplies all the 110v power I need. The truck idles quietly while the inverter is in use. Very neat arrangement. No generator to lug around, no gas to mess with, no noise, no maintainence!
horizons is offline   Reply With Quote
Old 12-10-2016, 09:51 AM   #18
RxGuy's Avatar
Bummer. That's unfortunate.
Thanks for everyone for all the feedback.
Old 04-26-2017, 09:29 PM   #19
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
A site called HFQPDB.com has man of the latest coupons and you can often find one for the inverter generator. As far as "good neighbor" worthy -- it's a hell of a lot better than a contractor gen! I bought one of these and was breaking it in over the weekend and the noise didn't bother me sitting directly on the opposite side of the wall, nor did I find it worrisome with regard to bothering my relatively close home neighbors. This is my first camping generator so I can't compare to yamaha or honda but it seems like it will be just fine.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 04-26-2017, 10:12 PM   #20
1988 29' Excella
2008 25' Safari SS SE
You want 2 generators, and the interconnect cable to run you roof AC
mbutterfield is offline   Reply With Quote
Harbor freight polishers? lewishw Cleaning, Stripping & Polishing 53 01-23-2013 01:54 PM
Cheap LED Tailight conversion at Harbor Freight? ronstory Lights - Interior & Exterior 4 07-25-2008 06:41 AM
Harbor Freight has a sale on 45W solar array bobechs Generators & Solar Power 10 07-11-2005 09:20 PM
Harbor Freight = Hubby's Heaven ! Herm and Debby 1970-79 Tradewind 2 12-20-2004 07:04 PM
Harbor Freight Buying Tip... malconium Commercial Listings 19 09-09-2004 06:22 AM
