Old 06-02-2020, 03:53 AM   #1
2013 Interstate Coach
fort mcmurray , Alabama
generator won't start
My 2013 airstream interstate lounge propane generator won't start.It was working before winter storage.When I pushed the start button, nothing happened.It looks like a control system problem.
I did the check as the list below.
1 - propane solenoid turned on, furnace, water tank and stove all working.
2 - Propane tank is full.
3 - The battery disconnect switched on.
4 - I have enough voltage on the house batteries. I ever connected the shore power.
5 - The inverter switched to "charge only".
6 - I did "prime" the generator by pushing the switch to "Stop/Prime" before trying to start it.
7 - All appliances that use AC power switched off.
lian jin is offline   Reply With Quote
Old 06-02-2020, 04:04 AM   #2
Long Island , New York
2013 airstream interstate generator
Welcome to the forum!
Sorry . . . I don't have any specific feedback on your situation, but you might find a better audience in the following "Sprinter and B-van" forum:
https://www.airforums.com/forums/f240/
There are very knowledgeable Interstate folks over there, who will be able to point you in the right direction. If you see a relevant earlier thread listed there, you could "Quote" a particular post and ask for advice.
Hopefully they will also notice this thread in the list of recent discussions. If not, starting a new thread in that forum would be a good move IMO.
Good luck,
Peter
FYI
FWIW
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
Generator won't start nancyo Sprinter and B-van Forum 13 07-30-2014 03:51 PM
Generator won't start arifarda Generators & Solar Power 3 09-14-2012 12:38 AM
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
2000 diesel pusher 35xc generator won't start from inside dhshipley Generators & Solar Power 0 09-17-2009 11:21 PM
