09-19-2022, 07:07 AM
#101
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by gypsydad
I see folks posting the use of 2 of these units all the time here, UB. Must work out fine for running 2 AC's; plus value of not having to lift/move 95+lbs in one generator, like I was doing with the Champion 3400 Dual Fuel...to me, the value of the Honda 2200 at 40~lbs is great...plus to propane fuel is my preference on any of these. If I needed to run 2 AC's, say in FL or TX in summer, likely would consider a second Honda 2200; but I don't see that happening anytime soon...Heck, with all this EV talk, I expect there to be a "new revolution" any day now where I won't need my F250 nor my Honda!
Hi
Most of the time, when you see this or that, all of the details aren't fully available. I've run a pair of A/C units on a 30A shore power plug. No that was not intentional, but hey, it worked just fine. The trailer was pulling 33A at the time and it cooled down nice and fast.
Do that for very long and the connectors involved will have a bit short life. Indeed with the wiring at many campgrounds, the A/C units will have a short life as well.
Generators have multiple components to them. The engine puts out some amount of power at sea level running on gas. Run it on propane at altitude and it puts out less power. Brand new in great shape, the engine puts out way more than it needs to at sea level. At some point, it *does* become an issue. Inverters have electronics in them. They get hot. That makes them more likely to break. Hot sun at altitude is not going to help them. Does something trip out when they get to hot or do they just die? who knows ....
There are lots of things that can be run well past their ratings. You take a risk when you do. You should be aware of that risk.
09-20-2022, 12:11 PM
#102
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Hi
Yea, I have been there done that also; but tripped the breaker after about 10 min. Easystart makes the job much easier on running the AC's; since I have not tried/run 2 AC's with 2 Honda 2200's, not sure the 4400W load across the 30A connector would be the way to go. I thought I read hear some folks ran a second cord/plug to use 2 AC's with 2 Honda's? Never considered trying to use just the 30A plug.
11-16-2022, 07:23 PM
#103
2022 23' Flying Cloud
Watsontown
, Pennsylvania
This was mentioned awhile back in this thread but not well noticed. It is worth noticing. New Honda eu3200i generator. 3200 watts. Runs a 13.5K AC without Easystart plus a lot more. Hutch Mountain has coming soon on the propane conversion kit.
Dimensions: 22.5 x 12.0 x 17.8 inches
Noise: 58 dB(A) @ rated load, 54 dB(A) @1/4 load
Weight: 59.1 pounds
Compared to eu22001i:
Dimensions: 20.0" x 11.4" x 16.7"
Noise: 57 dB(A) @ rated load 48 dB(A) @ 1/4 load
Weight: 47.4 lb.
https://powerequipment.honda.com/gen...models/eu3200i
Hardly bigger or heavier than the popular Honda eu2200i. Pricey as expected from Honda.
12-05-2022, 01:11 PM
#104
2022 33' Classic
Chesapeake
, Virginia
Interesting. I'm considering a EU3200i vs a EU2200i, same weight, more power. I only need to run one 15K AC unit, not planning to camp in the middle of summer. I'm wondering if I'd need an easy start installed with the 3200i.
12-05-2022, 02:25 PM
#105
2015 23' FB International
2007 19' International CCD
Steamboat Springs
The specs on the Honda website states that it will run up to 13500 btu A/C. I suspect this is based on the starting surge. So my guess is that installing a soft start on a 15500 btu A/C would be beneficial.
12-05-2022, 04:12 PM
#106
2019 25' Flying Cloud
Houston
It is heavier. 59.1 lbs vs. 47.4 for the EU2200i. It is also louder. The engine is barely larger, 130cc vs. 121cc. It claimed output is much higher at 2600W continuous vs. 1800W, but the price. You can buy two EU2200i's for one EU3200i.
12-06-2022, 05:59 AM
#107
2022 33' Classic
Chesapeake
, Virginia
The weight is manageable, I don't want 100 lbs to heft. I'm already lifting a Propride stinger. The price is what it is. The EU2200i may run one AC with EasyStart installed, but not much else. I didn't really want to buy two generators.
12-07-2022, 09:04 AM
#108
, Texas & Wyoming
Posted here before on this one...my Honda2200 with propane conversion integrated into the Honda, from Genconnex, runs my 15000AC just fine, which is reason I purchased. Two friends with Airstreams had this model, with propane also from Genconnex and were happy with performance running their AC's. I was able to try it on my 28'AS one camping trip while up in Banff few years back, so I knew it would work. I also had talked with Micro-Air tech couple years back when I still had my Champion 3400 Dual Fuel about the Easystart and the Honda 2000 since they had run a series of tests on several generators, before Honda had the new 2200, and back then, they confirmed it ran the 15000AC; so did the Yamaha 2000 back then, with the Easystart installed.
I sold my 3400 Champion Dual Fuel, primarily because it was 95lbs; primary reason. It was also a bit louder than the Honda, but not bad. I liked several features of the 3400, including remote control, and price when i purchased it was ~$800 I believe...but loading/unloading became a chore and I thought the Honda2200 at half the weight would work better for my use.
If I used my generator a lot doing more boondocking where I need my AC, I would likely get a second Honda2200 for the flexibility of running both AC's, but one works for me when needed. The 15000AC cools our 28'; just takes a bit longer than it does with both AC's going.
