Old 02-14-2020, 03:47 PM   #1
2017 16' Sport
Lansdale , Pennsylvania
Generator
Considering a Honda generator eu2200i with 30A outlet.
Thoughts?
What will it run such as Tv, ac etc?
Gould2749 is offline   Reply With Quote
Old 02-14-2020, 04:03 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Thoughts?
By itself, it should run everything but the AC. Reportedly with an "EasyStart" upgrade to the AC, you can run the AC with one if you shed all the other loads. If you parallel 2 of the EU2200i generators you can run anything you can run on a 30A shore power connection.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 02-14-2020, 04:41 PM   #3
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
There are multiple generator threads on this forum. Recommend a few searches.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 02-14-2020, 04:46 PM   #4
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Thoughts?
Gould2749, you canít beat the Honda for quality and performance. That said, youíd need two of the Hondas in parallel to get to 30A
Another option is a Champion like the 3400 Dual Fuel (connected to the Airstreamís low pressure propane port). It has a 30A receptacle and will run one AC without an EasyStart or two if they have EasyStarts.
The Campion weighs twice as much as one Honda so thatís a concern.
Good luck!
Jeff
ID:	361100   Click image for larger version
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-14-2020, 05:18 PM   #5
2007 22' International CCD
Generator
Iíve found the Champion is not that hard to lift, and Iím no longer young by any means.
I just put it in the bed of the truck and leave it there during our trip. Open the tailgate to run it.
It easily pumps out 30 amps and just barely grunts in economy mode (low idle) when the air conditioning compressor starts, even without an EasyStart module. Iíll get to installing the EasyStart gadget eventually to better protect the compressor and reduce the start up surge.
We used it during a very warm trip last September and ran it only on propane from my add-on quick connect setup and generator propane hose setup changes to draw from the Airstream tanks and regulator. See the ďwhich generatorĒ thread for details and pictures.
The only slightly odd thing I noticed is that with the Champion running on propane you have to turn off the gas supply valve on the Airstream quick connection port to cleanly shut it down. I installed a valve there as an afterthought and Iím glad I did.
Old 02-14-2020, 08:58 PM   #6
Sumterville , Florida
What is the propane consumption rate of the Champion dual fuel? Does it quickly diminish the AS supply? It seems it would be easier to go get more gas than propane for the AS.
I like the cleanliness and convenience of using onboard propane.
SVTOTEM is offline   Reply With Quote
Old 02-14-2020, 09:30 PM   #7
I donít know the exact consumption, but about 5.5 hours generator runtime maybe only took about 1/4 of a 20 pound propane tank. Iím not sure because I started with a partial tank and it didnít go down much.
I avoid the use of gasoline totally because when the Airstream is in storage I stash the generator inside it. Gas also stinks up the stuff in the truck, can spill, and does come with ethanol in it, and Iíd rather not have to clean the residue out of it.
Propane burns cleaner but does derate the generator output a bit. Itís not been an issue, even in the heat in Texas last fall.
Old 02-15-2020, 01:03 AM   #8
2013 25' FB Flying Cloud
Scotts Valley , California
We have a Honda 2200 with Hutch MTn propane conversion and Easy Start on the AC. No problem running the AC or microwave, but not at the same time. I hook it up to the propane fitting on the trailer and Iíve never put gas in it. It works great for us.
25Twin is offline   Reply With Quote
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
